Interior fan speed switch - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 10-20-2008, 02:16 PM Thread Starter
When i bought the truck (99 350) the fan only worked on full power, I lived with it like that until about a month ago when I changed the resistor (under the advice of my local Ford dealer) and it worked for a week and now has the same problem. When i changed the resistor I notinced that the plug that goes into it was damaged enough to let it unplug a little bit, could this be why my resistor keeps going bad? I don't want to put a new resistor in again untill I figure/fix why it is going bad. Any suggestions?
post #2 of 5 (permalink) Old 10-20-2008, 08:46 PM
try using some dielectric grease on the plug
post #3 of 5 (permalink) Old 10-21-2008, 12:52 AM
hi Sean:bad connection at resistor can cause all kinds of problems(loose terminals corrosion)clean and use dielectric,also these trucks were prone to overheating the fan switch connector and melting it.
post #4 of 5 (permalink) Old 10-21-2008, 03:28 AM
truckpilot's Avatar
+1, the stuff is great and just might solve the problem.
truckpilot is offline
post #5 of 5 (permalink) Old 10-21-2008, 11:55 AM Thread Starter
I'll go get another resistor today and try some dielectric grease. Thanks guys.
electric fan Jensen Gas Engines 3 07-18-2008 05:56 PM
Noob from the BC Interior MtnFordBC New Members Introductions 9 06-29-2008 11:48 PM
Leather Interior Question LaredoRV Truck/SUV Talk 8 05-17-2008 12:25 PM
