Heater Help - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 11-05-2008, 11:41 PM Thread Starter
BigDawg99's Avatar
Heater Help
When i have my Heater Running on my 04 F150 Fx4...the only place the heat blows out is from the Vents..it dont blow out of the Defrost area on top of dash or anywheres else..What is going on with the truck...Any help would be APpreciated
Pete
Fire Fighter 19
BigDawg99 is offline
post #2 of 9 (permalink) Old 11-05-2008, 11:53 PM
Sounds like the blendor in the heater box is either broken or stuck
post #3 of 9 (permalink) Old 11-06-2008, 12:05 AM
have had problems with the blend door motors on 04-05 f150's,it's behind the radio on top of heater box.
post #4 of 9 (permalink) Old 11-06-2008, 12:35 AM Thread Starter
BigDawg99's Avatar
Thanks man..so i take the radio off and i can see the box..
Fire Fighter 19
post #5 of 9 (permalink) Old 11-06-2008, 12:41 AM
yep the motor is on top of box,remove radio and switch blend control hot/ cold and see if it moves.
post #6 of 9 (permalink) Old 11-06-2008, 08:09 AM
not to hijack the thread... but i have the 02 explorer and when the blowers on no matter what setting it always blows out on your feet and to the rear vents behind the center armrest... just wondering if this is normal....
post #7 of 9 (permalink) Old 11-07-2008, 01:14 AM
this isn't normal sounds like the mode door is stuck/broken or the actuator isn't working,i will check manuals to see.
post #8 of 9 (permalink) Old 11-08-2008, 01:55 AM
hi i did some referencing and on your system it is vaccuum controled,check and see if you have vacc at the tap behind glove box if not check at oneway valve under hood.
post #9 of 9 (permalink) Old 11-08-2008, 08:17 AM
thanks alot ill look into it see what i come up with
NEED HELP: Musty-smelling heater Gord Interior 12 01-03-2013 01:31 PM
NEED HELP: 2004 F150 Heater Problem BigDawg99 Interior 11 12-19-2009 08:38 AM
