Rear Seat Removal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 01-06-2009, 11:27 PM Thread Starter
BluByu1986's Avatar
Rear Seat Removal
I've got a '05 Screw with Black Leather interior. How do you remove the back section of the rear seat. Everytime that I go over a hard bump, I can hear a rattling sound coming from behind the rear seat. I know that it's not in the seat bottom part, cause that part flips up and out of the way and I can see everything under it, just my Sub box and jack.
I've tried lifting up, pulling on the taps..... Don't know, stumped........
BluByu1986 is offline
post #2 of 6 (permalink) Old 01-07-2009, 01:55 AM
here's the proceedure from manuals-Remove the safety belt cover.
Remove the fasteners cover.
Remove the 2 nuts.
Lift up and remove cover from safety belt tower.
Using a suitable tool, release the mini-buckle.
NOTE: There are retaining clips that must be released to remove the rear seat backrest.
NOTE: The rear seat backrest trim cover and foam pad is removed for clarity.
To locate the retaining clips, align a screwdriver with the inboard portion of the outboard LATCH attachment points. Be careful not to damage the seat trim covers. Make contact with the rounded portion of the backrest frame and work the screwdriver upward until the screwdriver clears the rounded portion of the backrest frame. At this point the screwdriver should be located at the access hole. Press down on the backrest slightly (this is crucial, otherwise the retaining clip may not release), press the screwdriver rearward to release the retaining clip, then lift the backrest upward. Repeat this process to release the other side of the backrest.
post #3 of 6 (permalink) Old 01-07-2009, 07:43 PM Thread Starter
BluByu1986's Avatar
Thanks for the procedure for removing the seat back. Appreciate it.
Cheers,
post #4 of 6 (permalink) Old 01-08-2009, 01:53 AM
hopefully it helps you,inford wouldn't let me download the pics and the first one i did was a pita!
post #5 of 6 (permalink) Old 01-08-2009, 10:44 AM
http://www.ford-trucks.com/article/i...2008_F150.html
This article claims to be an easier way than the suggested method.
hedge is offline
post #6 of 6 (permalink) Old 01-08-2009, 12:36 PM
HD Chrome's Avatar
Check this video out, it shows how to remove all your seats and how to re-skin them. Very interesting watch...
http://www.truckblog.com/tv/katzkin_...r_installation
HD Chrome is offline
seat covers. canadian.bacon Interior 7 11-17-2008 05:03 PM
Gen 1 Lightning Seat BapeStaarr Interior 0 10-22-2008 01:38 PM
