NEED HELP: idles but no gas pedal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-27-2009, 08:05 PM Thread Starter
Hoping for some help. I had a problem with my F450 4X4 auto 7.3 p.s. last week where i lost the gas pedal. Turns out it was a fuse blown. Worked for 2 days and same thing happened again, but the fuse is good. We lose the dash (speedo,tach etc) also when this happens. Probably a broken wire or short, it did possibly make a little smoke before the pedal stopped working, but the fuse being good is very strange to me. Any help would be appreciated. Thanks.
peewee99 is offline
post #2 of 7 (permalink) Old 12-27-2009, 11:13 PM
Check the harness under the valve covers. It is know to short and here is a link.
http://www.accuratediesel.com/shop/96.html
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod, NC Hornet's CCV Mod
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
BD Power Auxiliary Trans Filter Kit
Diesel Site Coolant Filtration System
PSD911 is offline
post #3 of 7 (permalink) Old 12-28-2009, 08:27 AM
Dead pedal assaemblies were an issue for a while, I just can't remember which years. I believe it was early 2000's but it may have went back to 99's. if you know someone else with the same pedal assembly, maybe they would you switch it out to try it.
post #4 of 7 (permalink) Old 12-28-2009, 09:59 AM Thread Starter
I have had the valve cover wire harness problem in the past but it seem to make a no start situation. In this case it runs but the electronic gas pedal isn't being read. I guess I should not rule the harness out since we do seem to have some sort of wiring problem. Phil G, our truck is an 02, I have an 09 I'll check and see if it's the same pedal. Thanks for the replies so far. Jim
peewee99 is offline
post #5 of 7 (permalink) Old 12-28-2009, 11:31 AM
Jim...i know the 04-08 f150's have had this problem....truck would idle but no throttle imput....a pedal replacement would fix this on these series of trucks...Not sure if the SD's are like this.
post #6 of 7 (permalink) Old 12-28-2009, 04:43 PM
what fuse was blown?the fuel heater in filter housing was known to short out.
post #7 of 7 (permalink) Old 12-28-2009, 05:37 PM Thread Starter
Okay, we found we have 2 problems. I got the pedal back, it was a wiring problem in the actual fuse panel, we bypassed the fuse with an inline fuse and got our pedal back. Once it got running, it starts running rough after a few minutes wanting to stall. I'm going to have it scoped to see if it tells us what the deal is. We're thinking it could be the injector module or the cam position sensor, or maybe even that harness on the valve cover.
peewee99 is offline
Clutch Pedal Adjust Billy Mo F-150 Pre-1997 Forum 5 12-02-2009 12:08 AM
symptoms and how to - throttle pedal replacement '02 F350 Loadedagain Sticky Tech/How to Section 5 01-25-2009 10:58 PM
Gas? Silver FX4 Truck/SUV Talk 13 08-08-2008 10:20 AM
gas pedal problem help krazykanuk Ranger Forum 5 04-08-2008 08:46 PM
