HID Problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 08-17-2013, 10:07 PM Thread Starter
TRUKNUT's Avatar
Post HID Problem
I am having a problem with one of the HID's on my truck .
The lights come on as normal when I turn them on with the switch or put the
in drive . Then 5 or 10 min later (varies ) the drivers side light goes out .
I tried switching the bulbs from left to right just in case the left one was
heating up then going out but still the drivers side only went out . Now I
am wondering if I have a faulty ballast ? The shop that installed these is closed
for the weekend would anybody here know where I could go an purchase a
ballast or have any thoughts on this problem ?
Larry.
TRUKNUT is offline
post #2 of 6 (permalink) Old 08-17-2013, 11:00 PM
Larry.
if you swapped left to right, right to left, and the problem didn't move with it. then it's most likely a ballast..
maybe performance improvements. ?
how long has the kit been installed for?
alot of inexpensive kits only have 90days warranty..
post #3 of 6 (permalink) Old 08-18-2013, 02:50 AM Thread Starter
TRUKNUT's Avatar
The lights were installed a couple of years ago so I'm sure there is no warranty .
The upper lights are OTTO HID'S 8000K and the lowers are XENON 6000K .
The kits were not exspensive so hopefully a replacement ballast will not cost
to much if I can find one . If not I will have to replace the system .
TRUKNUT is offline
post #4 of 6 (permalink) Old 08-18-2013, 11:20 AM
You could swap a ballast from your fogs to the headlights for the time being. While you Order another set.
Sent from my iPhone using Tapatalk - now Free
post #5 of 6 (permalink) Old 08-18-2013, 12:21 PM Thread Starter
TRUKNUT's Avatar
Thanks Travis ... Interestingly I have been driving around all morning and the light has not gone out once . Maybe with me moving things there was a lose connection or something . . Don't you just love these guessing games lol .
TRUKNUT is offline
post #6 of 6 (permalink) Old 08-19-2013, 12:13 AM
Personally I'd replace it with a higher quality kit and wiring with a decent warranty..
or upgrade to a retrofit projector with higher quality products..
5yr warranty on this.
http://www.theretrofitsource.com/pro...ducts_id=12825
As well if you were to upgrade to retrofitted headlight.. it's all usable stuff.. only thing of that kit that would need be replaced is the bulbs.
hid install problem sprtyboy Ranger Forum 18 05-11-2011 09:45 PM
HID's mechanix61 Super Duty Forum 15 02-19-2009 02:13 PM
HID Light Problem.... Need Help??? ChadH F-150 2004 to 2008 Forum 5 12-31-2008 04:08 AM
HID's LayinHp Lighting 5 10-06-2008 08:14 AM
Which HID's Roadwarrior Lighting 1 02-28-2008 10:35 PM
