Reverse light upgrade - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 11-16-2013, 09:47 PM Thread Starter
TRNRBILT's Avatar
Ok I've been doing a bit of searching and found that you can mod an 894 bulb to fit into the 921 socket, the other option is a set of Cree LED 921 bulbs. Just looking to see if anyone has any thoughts on either. I tried some LEDs that I had ordered for the side markers, license plate lights and interior lights in the rear but found them to be no better than stock. So not too sure if the cree LEDs will be better or not. Also not sure about the 894s being too hot for the housing(not that they will be on very long though)
http://www.skidmore.edu/~pdwyer/e/backup_bulbs.htm
2 pcs Car/Truck/Vehicle T15/T10 High Power CREE LED Projector bulb 912 921 Reverse Backup SMD LED Light White - Compatible Bulb Model(for reference only):T10 T15 158 168 192 193 194 2825 921 W5WB W5W 2821 1250 1251 1252 12256 12961 147 152 159 161 194NA 259 280 285 175 184 2450 2521 2525 2652 2827 2886x http://amazon.ca/dp/B00DCOHOW8
Thanks James
TRNRBILT is offline
post #2 of 4 (permalink) Old 11-16-2013, 10:22 PM
do what lumberjerk did
that was a fun thread
post #3 of 4 (permalink) Old 11-16-2013, 10:31 PM
I did the 894 mod. I've noticed some melted housings a bit. And light output on the ground made no difference.
Cree led are way better quality, however there is so many different types and luminous flux output. Also how the led is wired in the bulb will also change the output. LEDs are simple yet very complex. There are different type of Cree LEDs used which will differ the output substantially.
I started a project to add a reverse tailgate light bar but haven't finished due to other projects and such.
post #4 of 4 (permalink) Old 11-16-2013, 11:22 PM Thread Starter
TRNRBILT's Avatar
If it didn't take so long for me to upload pics on here I'd go get a picture of my truck. Currently I have the same as lumberjack had but they're on the roof. Haha. You'd love em.
Maybe I'll start with the 894 mod. I think a buddy has a few of them at his shop in the "have them just incase but will never use them drawer" of his toolbox
TRNRBILT is offline
reverse lights problem grinder4.2 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 6 12-10-2012 02:22 PM
transmission hesitates going into reverse sms Driveline and Transmission 3 09-22-2012 07:52 AM
Reverse Light Solutions? RedThunder Exterior 10 01-25-2012 12:04 PM
Reverse Sensor going off for nothing RJohn357 F-150 2004 to 2008 Forum 10 01-27-2009 09:31 PM
08 Reverse Camera? 04STXHERITAGE F-150 2004 to 2008 Forum 15 12-22-2008 07:49 PM
