Daytime Running Lights - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 21 (permalink) Old 07-16-2014, 03:48 PM Thread Starter
stormy663's Avatar
I am surprised to find that there are no daytime running lights on my 98 Explorer. It was an option according to the owners manual. Any suggestions on getting them to work (a OEM module, aftermarket module etc)?
Doug
01 F150 XLT
00 F350 Superduty
98 Explorer Limited
stormy663 is offline
post #2 of 21 (permalink) Old 07-16-2014, 04:17 PM
I like Fords Too's Avatar
crappy tire had a conversion kit - Idono if they still do but maybe
I like Fords Too is offline
post #3 of 21 (permalink) Old 07-17-2014, 01:51 AM
I hate day time running lights myself. I had a '95 F-350 that I unplugged and removed the module. It was located behind the front bumper on the left side. It might be something similar on your explorer or even a pulled fuse if a previous owner had the same idea as me.
post #4 of 21 (permalink) Old 07-17-2014, 09:51 AM
I hated my airbags, so I unplugged them and removed them too.
post #5 of 21 (permalink) Old 07-18-2014, 11:01 PM
Start with the parking brake switch. Does your Brake warning indicator work? If so, start with fuses and work your way to the module. Might be the same problem for your cruise control.
post #6 of 21 (permalink) Old 07-19-2014, 11:44 AM
i unplugged my drl like 8 years ago. got a ticket this year for no DRL. $57
post #7 of 21 (permalink) Old 07-19-2014, 12:23 PM
When my DRL Module went years back I put changed it with the DRL delete plug DRL module was $140.00 and the delete plug was $ 12.00 the way I see it if I want DRL I'll turn on the headlights
post #8 of 21 (permalink) Old 07-19-2014, 01:25 PM
Maybe I'm missing something here, but what's the big deal with DRL's anyway ?
Who cares if they're on or not, it's not like you can see them on your vehicle when you're driving.
The supposed premise of DRL's is to make your vehicle more visible to oncoming traffic.
I guess you guys are turning them off because it looks cooler, or just sticking it to the man because he told you its the law ?
Not trying to stir things up, but just curious as to the thoughts behind consciously turning them off.
Don't get all offended, I personally couldn't care any less one way or the other.
post #9 of 21 (permalink) Old 07-19-2014, 03:56 PM
Saves headlight bulb use.
Not having control to shut them off/on is another thing.
post #10 of 21 (permalink) Old 07-19-2014, 04:50 PM
Headlight bulb use….seriously ?
Better stop driving on those tires then, the more you use them, the more they wear out.
Stay parked in the driveway saves tire use by that logic.
2000 expedition daytime running lights cammdoc Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 2 02-06-2011 02:22 AM
NEED HELP: Daytime running lights Vellu F-150 Pre-1997 Forum 4 05-23-2010 04:48 AM
99 Lost daytime running lights ml878us F-150 1997 to 2003 /04 Heritage Forum 2 04-06-2010 04:06 PM
Day Time running lights Waborita92 Ranger Forum 5 01-02-2010 06:33 AM
Daytime running light module stormy663 Ranger Forum 0 11-11-2008 12:09 AM
