headlight bulb replacement - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 04-03-2008, 09:49 PM Thread Starter
FRagE's Avatar
Do I have to unscrew the hole headlight to change the bulb ? I cant access the bulbs from the back.
Any help?
FRagE is offline
post #2 of 8 (permalink) Old 04-03-2008, 10:12 PM
What kind of truck do you have? Need more info.....
post #3 of 8 (permalink) Old 04-03-2008, 10:17 PM
if its a 97-03 style just pull the 2 tabs on the top and it slides out change and push back in pop the tabs down... they may need lube dont force them but its easier then skinning your nuckles raw.... and cheaper then hiring the 8 yr old next door to do it haha
post #4 of 8 (permalink) Old 04-03-2008, 10:18 PM Thread Starter
FRagE's Avatar
its 2006 f150
FRagE is offline
post #5 of 8 (permalink) Old 04-03-2008, 10:40 PM
Smokefan's Avatar
One bolt on top, 2 down the inside. Than you lift the tab in the fender, light should pull straight out.
2011 Chevrolet Camaro RS2SS
2007 Pontiac Grand Prix GXP
2007 Ford Crown Victoria P71
Smokefan is offline
post #6 of 8 (permalink) Old 04-03-2008, 10:47 PM Thread Starter
FRagE's Avatar
thank you,
do I have to mark the screws or something or they are just screwed tight and no adjusting the light is nessesary?
FRagE is offline
post #7 of 8 (permalink) Old 04-03-2008, 11:08 PM
post #8 of 8 (permalink) Old 04-03-2008, 11:30 PM
Smokefan's Avatar
Originally Posted by FRagE View Post
thank you,
Just snug them up, these screws are for holding the lense and not adjusting
Smokefan is offline
Next Project, U joint replacement jos1959 F-150 1997 to 2003 /04 Heritage Forum 13 08-30-2008 02:06 AM
Burnt out headlight TRUKNUT Lighting 24 05-31-2008 11:38 AM
Bulb Question CanadianRanger Ranger Forum 8 05-19-2008 09:33 PM
Maintenance Manual - Mirror Replacement coggerwayne F-150 2004 to 2008 Forum 2 04-26-2008 03:52 PM
Headlight Removal??? white4by4 F-150 2004 to 2008 Forum 5 02-06-2008 12:40 AM
