Need help No hi beams - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 41Likes
post #1 of 30 (permalink) Old 10-17-2016, 04:33 PM Thread Starter
Need some help with headlights. 04 F150 Auto head lights, drl. No high beams when I push lever forward. Light comes on in dash but no hi beams and low beams turn off.
post #2 of 30 (permalink) Old 10-17-2016, 08:35 PM
No serious help for you Glen, I'm guessing you've probably done the basic troubleshooting with connections, nicked or cut wiring etc.
Now, if you wanted to know where to get live streaming of sports events..... I could fix you up.
CanadianRanger and Mrmagoo like this.
post #3 of 30 (permalink) Old 10-17-2016, 10:27 PM Thread Starter
Ya, it is a weird one because daytime running lights still work.
Movies too, eh!
SVT4MT likes this.
post #4 of 30 (permalink) Old 10-17-2016, 11:14 PM
IT maybe the DRL module
CanadianRanger and SVT4MT like this.
post #5 of 30 (permalink) Old 10-18-2016, 02:22 AM
First thing...make sure bulbs aren't burnt out on the high beam element. I've seen this three times, that I can remember, where a guy comes over over cuz no high beams. Then I start troubleshooting and find both high beam elements broken. I think what happens (sometimes) is, when one bulb burns out, it overloads the other, and it pops too! I changed both bulbs in those cases and that's it. Something to try anyway. Good luck Glen.
post #6 of 30 (permalink) Old 10-18-2016, 06:18 AM
What happens when you bring the lever toward you instead?
SVT4MT likes this.
post #7 of 30 (permalink) Old 10-18-2016, 10:44 AM
I like Fords Too's Avatar
+1 ^
if flash to pass still works the bulbs are good
owner's manual might tell you if there's a relay in the relay / fuse box under the hood for the H beams
do you still get a "click" from the high beam switch ?
if not and flash to pass dosen't work either then there might , might be a link in the steering cllm that's poped out/off
my 80's dodges had a metal link bar in the steering cllm - it ran between a "paddle" on the stalk and a "paddle" on the high beam switch which was actually at the bottom end of the steering collum
the only thing that held the link rod in place was a dimple in each "paddle"
IF you find a simular problem a little dab of silicone on each end of the link rod usually kept it from droping out of place again later for me
SVT4MT likes this.
I like Fords Too is offline
post #8 of 30 (permalink) Old 10-19-2016, 11:41 AM Thread Starter
When I try ftp light comes on in dash but nothing else happens. truck in for lower ball joints today so will pull headlights when I get it back and check bulbs. Have extra set so will see what happens.
Fordsforever6.0 and SVT4MT like this.
post #9 of 30 (permalink) Old 10-21-2016, 11:15 PM Thread Starter
Well here is the latest on my headlight problem. Checked fuses, changed out headlight bulbs. Still no high beams. Light in dash does not come on now either.
High beam relay clicks so I am assuming it is ok. Push mfs forward for high beams and it goes from low beams to drl. No ftp. Thinking mfs. Any thoughts?
SVT4MT likes this.
post #10 of 30 (permalink) Old 10-22-2016, 12:05 AM
Jack-Daniel's Avatar
I think the relay is integral to the DRL module,maybe source one from a scrapyard and try swapping it .
SVT4MT likes this.
2011 F150..5.0 XTR Super Crew
Jack-Daniel is offline
low beams/highbeams and foglights not working myneedforspeed Lighting 0 12-19-2007 12:32 AM
