DRL issue - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 04-27-2008, 04:11 PM Thread Starter
DRL issue
Hey...not sure if it has happened to anybody else before but I have a '98 F150 4x4 and I turned on my truck today and when I shut it off the daytime running lights wouldn't shut off when I turned the truck off. I also noticed that the highbeam indicator stays on but when I turn the headlights on, it goes off. I had this issue once before but it fixed itself after a few minutes, I tried to disable the DRL by pulling the fuses but it stays on even with the fuses out, I pulled the highbeam fuse as well but that didn't help either, any help would be greatly appreciated. The battery is disconnected so I don't kill it. I fiddled around with the multi-switch as well but that didn't help either.
notmuchmud is offline
post #2 of 6 (permalink) Old 04-27-2008, 04:23 PM
i just unplugged the DRL on mine.
I did this to save the life of my HID headlights.
Its the big white plugin in the center of the pic
post #3 of 6 (permalink) Old 04-27-2008, 10:18 PM
Do you have a timer switch for the DRL's I do on my 99 it's beside your interior light/dimmer switch if ther's two little wheels side by side you might have accidently rolled the switch on without noticing, they turn off so many minutes/seconds after you turn off your truck to let you see where your going at night so you don't trip over your neighbours cat, or run into a door....If it's that don't worry I did it before too.
post #4 of 6 (permalink) Old 04-27-2008, 10:27 PM
DRL should never shut off. ive never heard of it/
post #5 of 6 (permalink) Old 04-27-2008, 10:36 PM
I think he means when he turns off the truck the DRL's stay on, so it might just be the switch
post #6 of 6 (permalink) Old 07-05-2008, 11:44 PM
If the high beam indicator on the dash is on after the truck is turned off and the lights are off I would say he DRL module needs to be replaced
How to Disconect DRL on 04-08 4.6L. white4by4 Lighting 27 04-24-2011 10:44 AM
HELP!!!!! DRL Needed NOW!!! mitchbtu Ranger Forum 7 06-05-2008 07:20 PM
Quick way to disable DRL on 97's f150phule Lighting 6 04-07-2008 12:38 PM
