HID problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 08-17-2008, 11:10 PM Thread Starter
BMac's Avatar
HID problems
I need some help, I installed some HID's. They are an h13 high/low kit made by RTX.
Anyways when I have my truck running and I turn on the lights it kills the motor. I have them grounded to the batteries so I know the ground is good.
Only other thing i've thought of is to get some relays and draw from the battery
Anyone else have any ideas? I don't know much about these HID kits. Thanks in advance
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #2 of 8 (permalink) Old 08-17-2008, 11:49 PM
My kit draws power directly from Battery
There may be a possibility that your transformers are not connected to metal, they also have to be looped to ground
post #3 of 8 (permalink) Old 08-18-2008, 08:03 AM Thread Starter
BMac's Avatar
by transformers do you mean the ballast? Because I have the attacted to them screwed into the header panal which is fiberglass so I guess i'll try running a ground from the screw
BMac is offline
post #4 of 8 (permalink) Old 08-18-2008, 11:19 PM
Yep
try to ground them and see if it solves the problem
post #5 of 8 (permalink) Old 08-18-2008, 11:25 PM Thread Starter
BMac's Avatar
I went and talked to a guy who owns a aftermarket performance shop around here. Walked away with two relays and a diagram on how the manual should have told me to wire them.
Right now with the HID's drawing power from the stock system it's causeing too much strain on the elec system so its killing the engine.
Therefore drawing power directly from the battery should alieviate the strain and solve my problem.....I hope!
BMac is offline
post #6 of 8 (permalink) Old 08-18-2008, 11:28 PM
The guy is correct,
I'm surprise that your kit didn't come with harness to do that
post #7 of 8 (permalink) Old 08-18-2008, 11:32 PM Thread Starter
BMac's Avatar
me too, guess ya get what you pay for! haha
BMac is offline
post #8 of 8 (permalink) Old 08-18-2008, 11:40 PM
Some time, thats how it works
HID install Northern Supercrew Lighting 20 09-29-2008 12:14 AM
HID Lights... fordtough.ca Lighting 10 06-18-2008 10:42 PM
