HID's - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 10-05-2008, 11:49 PM Thread Starter
HID's
ok i can buy a set of HID's for a good price
some questions, is it normal to need to hook the light plug in backwards for reverse polarity ? they wont work the right way but will if the plug is reversed....
second, the factory light has a bulb "hat" does this need to be remoed so it wont melt or is it ok as long as it doesnt touch the bulb ?
and any pro's cons for HID's
there a 9006 bulb and 6000 series brightness.....for a 2002 ford explorer
post #2 of 6 (permalink) Old 10-06-2008, 12:16 AM
BMac's Avatar
The "hat" you speak of is fine as long as the bulb doesn't come in contact with them.
I'm not sure i'm understanding what you mean by hooking the light plug in backwards?
HID's are awesome...only con I can think of is they are technically illegal
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 6 (permalink) Old 10-06-2008, 12:31 AM Thread Starter
the plug fits one way and locks into the oem harness but doing this the HID wont work if you unplug it rotate it and replug in it works....
post #4 of 6 (permalink) Old 10-06-2008, 12:45 AM
that's weird. it shouldn't do that. my kit went together great. i did have one left over oem plug for the heads. everything else went where it was supposed to. wifes escape same thing..i hope you get it figured out.
post #5 of 6 (permalink) Old 10-06-2008, 01:35 AM
sounds like something is wired backwards is this a new kit, if it is get it replaced
post #6 of 6 (permalink) Old 10-06-2008, 08:14 AM Thread Starter
its new never installed but no warrenty guy bought it and just never installed another buddy had the same thing on his lumina when he put them in had to reverse the plugs and a ring of blacktape just to make sure theyd stay together but its a tight fit i doubt theyd come free
ended up hooking them up on the same buddies s10 blazer man are they bright as hell might try and getahold of manuf see if they know whats up
HID's....legal or no? BMac Lighting 11 07-25-2008 12:05 AM
Which HID's Roadwarrior Lighting 1 02-28-2008 10:35 PM
