NEED HELP: Indicators flash intermittenly! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 07-10-2010, 02:34 PM Thread Starter
My left turn signal will flash (both front and rear) and will then suddenly stay ON...20Amp fuse looks good...where would i find some kind of flasher module in the truck?
dually is offline
post #2 of 4 (permalink) Old 07-10-2010, 02:36 PM
Send a message via MSN to R3LYK Send a message via Skype™ to R3LYK
While I can't help you personally, I think I speak for anyone who could that we need a little more information about your truck: namely which year is it?
R3LYK is offline
post #3 of 4 (permalink) Old 07-11-2010, 12:23 PM
the flasher relays are on the rh side of the brace by the accelerator pedal,we have had a lot of multifunction switches go bad,if when the flashers are acting up you play with the switch do they flash normal ?
post #4 of 4 (permalink) Old 07-12-2010, 05:33 PM
CDM76's Avatar
By clicking on his "public profile" you would probably note the following : 2000 F350 Crew Cab Dually 2WD Diesel
just fyi
CDM76 is offline
