Ball Joint question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 08-29-2011, 12:34 AM Thread Starter
Ball Joint question
Ok so I finally figured out why I get a vibe between 80-110kph. Turns out the pass. side upper control arm was shot and so are the lower ball joints. I got the arm fixed cuz thats all I could afford at the time but my question is this.
Since as far as I know the ball joints are original and if I replace them should I go with a normal set of ball joints or get a set that are slightly oversized 0.006" for worn lower control arms? The mechanic never mentioned the lowers at all.
post #2 of 5 (permalink) Old 08-30-2011, 10:30 PM
Blue Oval's Avatar
Either way make sure the replacements you get come with grease fittings.
Blue Oval is offline
post #3 of 5 (permalink) Old 08-30-2011, 10:34 PM
They still have those?
Make sure when going oversize that the holes are reamed for a proper fit.
post #4 of 5 (permalink) Old 08-31-2011, 12:35 AM Thread Starter
The ones I plan on getting are from Moog and they have the grease fittings, they come in two types, normal size and oversized. I just don't know if the lower control arms are worn to the point that I need the oversized ones.
post #5 of 5 (permalink) Old 08-31-2011, 01:33 PM
i just changed right lower and upper ball joints on my truck and the hub bearing at the same time and the 2 front shocks and only cost me 600 bucks OUCH i only intalled regular lower ball joints from ac delco life time warrenty now i have to replace the left lower ball joint i am lucky since under warrenty i put 3 years ago
gilligan is offline
Ball Joints swackly Suspension 8 10-16-2010 11:09 PM
ball joint replacement dwh Super Duty Forum 4 04-23-2009 02:06 PM
Next Project, U joint replacement jos1959 F-150 1997 to 2003 /04 Heritage Forum 13 08-30-2008 01:06 AM
wtf...05 u-joint snap-on Driveline and Transmission 2 05-15-2008 01:34 PM
