Front Suspension Lowering - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 34 (permalink) Old 02-23-2012, 06:33 PM Thread Starter
TRUKNUT's Avatar
Post Front Suspension Lowering
I am thinking about lowering or having the front lowered on my truck about 1"
and am wondering if any one has had or done this. I have already installed a
Belltech drop shackel kit on the rear and the truck sits fairly level but would like
to bring the whole truck down about 1".
Any input or sugestions on how to or where to get this done would be apreciated .
Larry
TRUKNUT is offline
post #2 of 34 (permalink) Old 02-23-2012, 07:27 PM
Seek out the wisdom of Taisa899. He's the resident expert on getting a truck to sit low. Without flattening tires!
post #3 of 34 (permalink) Old 02-23-2012, 09:11 PM
I think belltech makes some coilovers for 0-3" drop
post #4 of 34 (permalink) Old 02-24-2012, 08:20 AM Thread Starter
TRUKNUT's Avatar
Belltech does have a 0-3" front drop kit that will give me what the look I want. Wondering two things. Is this somthing I can do myself or Is this something that should be done in a shop ?
I installed the rear drop shackels in my driveway but are the fronts a different animal ?
TRUKNUT is offline
post #5 of 34 (permalink) Old 02-24-2012, 09:34 AM
Yes. You most likely will need some air tools. As you will need to take out the strut assembly. caliper. I think balljoint too., lower.
post #6 of 34 (permalink) Old 02-24-2012, 10:11 AM
Im stupid new here, and dont know ya, but if you need to take it to a shop, then come to my place. I have the tools minus a lift, but we can get r' dun
Sully is offline
post #7 of 34 (permalink) Old 02-24-2012, 10:13 AM Thread Starter
TRUKNUT's Avatar
Thanks Travis from what have have been reading on line here looks like a job that should be done in a shop.
TRUKNUT is offline
post #8 of 34 (permalink) Old 02-24-2012, 10:15 AM
coilover are just popping the shock out and a new one in place..... easy stuff with the right tools
Sully is offline
post #9 of 34 (permalink) Old 02-24-2012, 06:02 PM
Grant (lumberjack) and i had to pull his struts to put in his strut spacers.
We have access to air tools, jacks and fork lifts. So wasnt too bad.
You will need an alignment afterwards though..
post #10 of 34 (permalink) Old 02-24-2012, 07:04 PM Thread Starter
TRUKNUT's Avatar
It's probably not a bad idea to have an alignment after any front end suspension work.
Has any one here had belltech 25001 lowering strutts installed ?
TRUKNUT is offline
What lowering kit to get? Viper238 Street Scene 23 11-25-2012 02:58 PM
Rear Suspension Lowering Kit fordtough.ca Suspension 40 07-08-2010 12:18 AM
Lowering Kit stubbyranger Ranger Forum 0 03-09-2010 01:52 AM
Lowering Kit fordtough.ca Street Scene 9 02-04-2010 03:49 PM
