Ebc brake rotors - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 01-25-2013, 08:12 AM Thread Starter
Ebc brake rotors
I'm looking to upgrade my brakes it's time to change the brakes on my 2007 Harley. I found a great deal on ebc slotted and vented rotors with hawk pads. My question is I heard they will make noise is this true because the truck is heavy? I am going to do towing with my mustang to the the track and I do a lot of driving and want good stopping power with the obvious good looks with the 22' wheels any advice would be greatly appreciated thanks
Tommy
T_RAT is offline
post #2 of 8 (permalink) Old 01-25-2013, 12:29 PM
In the past i haven't had much more then maybe a whoosh or a whistle under heavy braking. It's the brake gases escaping.
Under normal use/ load not much different, just a little more grabby/ touchy. Which is a lot better feeling then mushy.
Trav
post #3 of 8 (permalink) Old 01-25-2013, 12:30 PM
I just threw some cross drilled and slotted rotors on with the best raybestos pads. All quiet and smooth. Much stickier feeling on the vancouver island highway. Aka 'rotor destroyer'
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #4 of 8 (permalink) Old 01-25-2013, 01:04 PM
I use Power Slot Cryo's with hawk hps pads, no noise or issues either http://www.frozenrotors.com/category/power-slot-cryo/
post #5 of 8 (permalink) Old 01-25-2013, 03:05 PM
TRUKNUT's Avatar
I would like to upgrade the callipers and rotors on my truck this summer. Been researching parts for a while now . To be honest it getting a little confusing . So many variables . I really need to get some sound advice on a complete kit .
TRUKNUT is offline
post #6 of 8 (permalink) Old 01-25-2013, 04:40 PM
Boss F150's Avatar
If you find the secret recipe for less then 3k share. I might be interested in your stockers if you do pull the plug on upgraded calipers.
Boss F150 is offline
post #7 of 8 (permalink) Old 01-26-2013, 05:28 AM
TRUKNUT's Avatar
So far the recipe is just under 5k fronts only ... not going to happen.
TRUKNUT is offline
post #8 of 8 (permalink) Old 02-13-2013, 02:23 PM
Big Daddy D.'s Avatar
I would recommend looking at Carbotech Performance Brakes #1521 HP Street pads for your 2007 Harley. Been using them on all 4 corners on my /06 Screw for a few yrs. now with great success. No noise, nearly zero brake dust (even after heavy braking), and rotor friendly. Last 2-3 longer than OEM pads. Greatly improved brake modulation over what you have now, I'll tell you.
At the moment I'm running Xtreme Stop drilled and slotted rotors both F & R.
BTW, Ford only improved the brake performance on the /09 models by 10% (big wup IMHO)
Just remember... if you go with a greater sized brake kit, it will limit you as to what rim sizes you can run with, trust me... I've looked into this...
Press on regardless!
Big Daddy D. is offline
Tow package but no EBC Bull_Auger F-150 2009 to 2014 Forum 5 10-23-2010 04:43 PM
Brake help Fordwheeler Super Duty Forum 3 09-25-2008 05:56 PM
Breaks and rotors? wayner147 Wheels and Tires 3 09-12-2008 02:04 AM
Raybestos rotors experiances anyone? Lightning Steve Wheels and Tires 1 04-04-2008 11:18 PM
