NEED HELP: Bearings question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 02-08-2013, 12:40 PM Thread Starter
Bearings question
I have friend that ask me if had bearing going bad and wondering they worry about the wheel problems like the wheel falling off or something like that while driving!!!
post #2 of 4 (permalink) Old 02-08-2013, 01:42 PM
I've had a few front wheel bearings go on mine..started with a "whine/howl" and then finally a "crunch/grind"..i drove home like that..altho slowly and it wasn't far..never had a wheel come off tho, suppose it's a possibility.
post #3 of 4 (permalink) Old 02-08-2013, 01:57 PM
Manford's Avatar
Very few bearings getting old and tired will result in catastrophic failure unless they are bone dry and heat to the point of failure. Long before that point comes, you will experience a fair amount of whine akin to tire noise on concrete. The exterior hub will also be hot to the touch, not just warm
Rear wheel bearings will demostrate diff fluid leaking onto the rear rotors or drums long before one of those head south.
Bearing maintenace should never be overlooking though, it is relatively cheap vs risk.
__________
ManFord
Manford is offline
post #4 of 4 (permalink) Old 02-09-2013, 07:08 AM
Depends on how long your friend plans on driving around with a bad bearing I think.
He should seek some professional help, the longer he waits, the worse things will get....
Tensioner Pulley Bearings BluByu1986 F-150 2004 to 2008 Forum 4 12-21-2011 06:45 PM
Question about the 09's Fordsy F-150 2009 to 2014 Forum 15 01-05-2009 06:12 PM
NEED HELP: Question Denis254 Ranger Forum 5 11-16-2008 01:26 AM
03 F150 XTR xtend cab-wheel bearings gman F-150 1997 to 2003 /04 Heritage Forum 5 06-29-2008 08:46 PM
