NEED HELP: nagging brake/rear diff issue - Page 2 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #11 of 17 (permalink) Old 05-22-2015, 06:00 AM
Big Daddy D.'s Avatar
Originally Posted by f150phule View Post
Talked to my dad and he made a good point. Since it only happens once it heats up it could be a wheel bearing.
With that much smoke and heat occurring, you would think that you would hear something as well, as far as wheel bearings go.
Or a bearing race spinning within the hub assembly.
Looks to me that things need to be taken apart and checked out for signs of wear and heat damage.
Press on regardless!
Big Daddy D. is offline
post #12 of 17 (permalink) Old 05-25-2015, 01:55 AM Thread Starter
Decided to give it one more try, ordered new calipers, pads, rotors and a flex line for the left rear. If it still does the same thing after all this then I wash my hands of this truck. It'll go up on autotrader/kijiji and it'll be someone else's headache.
post #13 of 17 (permalink) Old 05-25-2015, 12:14 PM
Just what my thoughts were
post #14 of 17 (permalink) Old 05-25-2015, 12:50 PM
I like Fords Too's Avatar
get that bearing checked while they have it all apart - better to find it then rather than later
mine also only seems to do it on left turns too
last fall I had to replace the left rear axle seal - it leaked axle lube all over the back of the tire so I'm thinking maybe a bad bearing was the reason the seal gave up
I'm not getting huge amounts of heat though - but I don't drive more than a few miles at a time and almost no highway driveing 'cept one ramp over to the next or the one after
I like Fords Too is offline
post #15 of 17 (permalink) Old 05-25-2015, 07:12 PM
Are the c-clips intact in the diff?
post #16 of 17 (permalink) Old 05-26-2015, 01:03 AM Thread Starter
The 2nd time it was in I had them remove the cover to change out the gear oil and told them to check everything inside to make sure there was no issue with the diff. I was told it was all good.
I planned on having them check the bearing while the right rear wheel is off.
post #17 of 17 (permalink) Old 06-10-2015, 12:58 AM Thread Starter
Finally this is fixed. Total cost over 4 trips to the shop just over $1000.
Replaced both calipers, new pads, new rotors, new flex lines both sides and did a test run on the hwy. Checked the wheel temp with a laser temp gauge and they are within 1 degree of each other so issue is resolved.
Wheel bearings are in great shape so no need to change them yet.
Rear Limited Slip Diff Noise zedeng Driveline and Transmission 1 04-18-2011 08:24 PM
Rear diff Bruicer Suspension 2 05-14-2010 03:35 PM
Rear Diff Axehandler Driveline and Transmission 1 02-05-2010 03:03 PM
Need info on 2009 rear diff Mar Ranger Forum 12 01-20-2009 08:35 PM
Rear Diff questions f150phule Driveline and Transmission 6 11-25-2008 12:59 AM
