EX springs in an SD - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 10-31-2017, 06:25 PM Thread Starter
EX springs in an SD
Hi,
2000 F350, SRW, 2WD, regular cab. Basic truck where the only options installed are a diesel with automatic, tow package and a sliding rear window. This truck is relatively light compared to SDs with extended/crew cabs, 4WD, dually, power everything, etc. The ride quality in the rear is extremely harsh- worse than further-optioned (heavier) SDs of the same era.
I've installed KYB mono tube shocks front and rear. I've also lowered the rear 2" using drop shackles, (for aesthetics). Dropping the rear made a huge improvement in ride quality. I figure this is due to reduced swing travel of the longer shackle during spring deflection, thus transferring less vibration to the chassis. However, I'd like to make further improvements.
An '08+ spring swap is being considered. However, I wonder about swapping the SD leaf springs out for a pair of Excursion's. Given that the Excursion is heavier in the rear than the SD, yet has lower rated springs, they should be more than adequate for how I use the truck. Does anyone have any experience trying this? What was the result?
Lots of people installing SD springs in their EX. I want to go the other way: EX springs in an SD.
Thanks.
koldcustoms is offline
Super Springs BluByu1986 Suspension 7 02-03-2014 12:00 PM
09' rear springs wrangler F-150 2009 to 2014 Forum 9 10-12-2012 09:16 PM
help concerning front springs fordfever300 F-150 Pre-1997 Forum 3 04-29-2011 08:48 PM
Broken springs Snowdoogie Ranger Forum 6 06-02-2009 09:10 PM
NEED HELP: Super Springs Suspension Sagehill F-150 Pre-1997 Forum 0 09-24-2008 03:45 AM
