NEED HELP: Strut swap - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 2Likes
  • 2 Post By Destructicon
post #1 of 6 (permalink) Old 02-25-2018, 08:49 AM Thread Starter
Strut swap
Will 2015 fx4 4x4, stock strut, Install in my 2wd 2006 f150.?
DBuck065Speed is offline
post #2 of 6 (permalink) Old 02-25-2018, 12:04 PM
Welcome, I'm not sure what changes were made between generations, I think when you're talking an almost ten year span, plus 2WD vs 4WD, chances are not good.
Then again, i don't know for certain, I've been wrong before.....why swap struts ?
post #3 of 6 (permalink) Old 02-25-2018, 03:13 PM Thread Starter
Why swap ?
My truck is 2006, these struts are off newer 2015 complete strut pair for 100$
thought Id get a slight lift and stronger spring rate.
Owner put 6 inch lift into his truck
post #4 of 6 (permalink) Old 02-26-2018, 04:25 AM
Gotcha, good luck, hope it works.
post #5 of 6 (permalink) Old 02-27-2018, 04:20 PM
They might work. The 4wd shock will be longer, I'm just not sure how that will mess with the rest your suspension components.
post #6 of 6 (permalink) Old 02-27-2018, 07:54 PM
Putting a 4x4 shock/strut in a 2wd truck, if the 4x4 one is longer, is going to bottom out before hitting the rebound bumpers (please feel free to correct my terminology for this.) This will lead to damage at both ends of the strut and possibly shear something off. Best bet is to look up the strut/shock part numbers for both vehicles and compare. If the same part number is used for both across several websites then go for it. If not, then more intricate technical specifications need to be examined. Length extended, length collapsed, diameters, bolt configurations, support hardware, etc...
herbz and Mrmagoo like this.
5.0 swap? T_RAT F-150 2004 to 2008 Forum 16 02-22-2013 05:39 PM
anyone gotten into a 4.6 swap? FX4Ranger Ranger Forum 11 05-14-2012 08:56 PM
Lower Frt Strut Bolt bboybean F-150 2004 to 2008 Forum 9 07-08-2010 02:13 PM
Engine swap? bluegoose Diesel Trucks 5 04-23-2009 02:44 PM
