susp. lift - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 11-20-2008, 11:17 AM Thread Starter
susp. lift
by doing the torson crank(35 7/8" to bottom of wheel well) and shackles in the back has/do you replace the shocks with longer ones so they don't max out and limit travel? and if so where and which ones(length) should i get?
thanks
rangerT is offline
post #2 of 5 (permalink) Old 11-20-2008, 12:45 PM
SCREWDRIVER's Avatar
no, you dont have to replace shocks...
ps...this topic has been covered so many times, please try the search button first
2oo5 F~15o Supercrew 4x4
SCREWDRIVER is offline
post #3 of 5 (permalink) Old 11-20-2008, 01:19 PM
With the small amount of lift that you will get from cranking the bars your stock shocks will be fine.
post #4 of 5 (permalink) Old 11-20-2008, 01:52 PM Thread Starter
oops...... thanks and my apologies
rangerT is offline
post #5 of 5 (permalink) Old 11-24-2008, 09:47 AM
An alignment will be needed tho
4x4.0 is offline
NEED HELP: How Big of lift? NVR2LO Suspension 12 11-11-2008 11:30 PM
how much lift do i need? arboc Wheels and Tires 12 10-16-2008 10:15 PM
Lift, what do you............... fordtough.ca Off Road 20 06-19-2008 09:17 PM
Lift Kits klewis Wheels and Tires 4 12-04-2007 02:48 PM
