upgrading torsion bars? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 12-09-2008, 11:35 PM Thread Starter
canadian.bacon's Avatar
i was reading a thread on an explorer forum that discussed this. basically that certain vehicles came with different rated torsion bars ( while have similar suspension design). any info on a "stiffer" bar for a ranger that would produce similar lift as a "torsion bar crank" but without over stressing the bar itself with said cranking?
they didn't really come to a solid answer but seemed to think a sport trac bar is stiffer then explorer bar. any actual info anywhere about various bars and spring rates?
canadian.bacon is offline
post #2 of 2 (permalink) Old 12-10-2008, 09:19 AM
Chris.S.'s Avatar
I believe you should be able to find that info on TheRangerStation.com
I know I've "heard" people discussing that and I know the Torsion bar has a spring(?) number that is included in the door sticker so once you know what you're after it should be fairly straight forward...
Just some dude from BC...
Chris.S. is offline
Ranger Torsion Bars Crank fordtough.ca Sticky Tech/How to Section 5 12-15-2012 11:19 AM
Step Bars Justin1635 Exterior 7 12-03-2008 01:53 PM
Nerf Bars Black Ice Exterior 6 11-27-2008 09:46 PM
Traction Bars..... fordtough.ca Truck/SUV Talk 7 07-13-2008 07:15 AM
Drawing of Torsion Bars adjustment mika Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 7 05-14-2008 11:59 AM
