Ball Joints - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 01-20-2009, 06:30 PM Thread Starter
swackly's Avatar
Ball Joints
How long should they last I installed a leveling kit in my truck on the weekend (2.5) and got a alignment done today My truck has only 36000 km and the tech at Ford said the lower right ball joint was loose? Could that be right? I had a Ford with 300000 km on the original bal joints 4X4 also
swackly is offline
post #2 of 9 (permalink) Old 01-20-2009, 11:59 PM
did they actually measure radial deflection on the joint(spec is .032")and if it's worn out should be covered under base warranty(no cost to you)
post #3 of 9 (permalink) Old 01-22-2009, 06:39 PM Thread Starter
swackly's Avatar
I didn't talk to the tech (they we on lunch) but they marked on the notes part of the bill How do you check them?
swackly is offline
post #4 of 9 (permalink) Old 01-22-2009, 07:15 PM
If it was installed wrong, maybe. Ball joints (yes even on a Ford...) should last a fairly long time, at least 200,000 km unless you're pounding them on gravel roads or heavy 4x4 usage. I have found that OEM stuff does last longer than aftermarket replacements, I think because that the original joint was installed when it was brandnew, and they do wear a touch in the socket.
It could also be that they are trying to make extra work for themselves, or perhaps have mistaken a loose wheelbearing for a loose balljoint. You'd think a tech should know better, but sometimes you'd be surprised. LR
post #5 of 9 (permalink) Old 02-01-2009, 04:03 PM Thread Starter
swackly's Avatar
I finally got time to look at the ball Joint it seem loose are they hard to replace press in Or buy new control arm? Haynes manual say replace control arm I would think ford would replace under warranty while in shop?
swackly is offline
post #6 of 9 (permalink) Old 10-15-2010, 10:24 PM
I just did my top Balls in my 08 F150 with 75,000 klicks 99% highway miles $761.00
08 Super Crew6.5 bed 3:73 gears 5.4 liter
Banks Powerpack Ram Air CAI
Torque Tube Shorty headers Duel Monster Exhaust
Ottomind Programmer Bi-Tron Additives Fuel Conditioner
[SIGPIC]
1961mercury is offline
post #7 of 9 (permalink) Old 10-15-2010, 11:25 PM
Swackly what year is your truck ? I'm thinkin they are trying to get you on the ball joint cause you did the 2.5" level, saying it's your fault and make you pay. Just my 2 cents worth shruggs
post #8 of 9 (permalink) Old 10-16-2010, 08:14 AM Thread Starter
swackly's Avatar
My truck is a 2005 I replaced my lower ball joints at 30,000km. I just hand installed the leveling kit and took it to ford for the alignment and they sayed they we lose. So I put new one in and got the alignment. Now at 80,000 everything was just checked out at ford again and is still in top notch condition. 50.000 with leveling kit no problem with wear on ball joints. 85% highway 25% towing 26ft house trailer. The moog balljoints are the best replacment
swackly is offline
post #9 of 9 (permalink) Old 10-16-2010, 11:09 PM
I put leveling kit on mine. and within 10k. under 60k. on of the shocks started leaking. said the leveling kit caused it. or could have.. and due to the leveling kit. they aren't covered.
NEED HELP: U-JOINTS! Tetford4X4 Truck/SUV Talk 20 09-30-2008 06:50 AM
NEED HELP: 2004 U-joints johnnyo888 Driveline and Transmission 0 09-12-2008 10:46 AM
