lowering rear end - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 04-10-2009, 05:39 PM Thread Starter
Blue08's Avatar
Send a message via MSN to Blue08 Send a message via Yahoo to Blue08
lowering rear end
hey all. I realize I haven't posted in a long time, I've been wicked busy. Now that I'm injured, I have lots of free time lol. Anyways, I plan to drop the rear end of my 08 F150 (5.4L tow package, so uprated rear springs/shocks) to as close to level as possible. I spoke with the service manager at the dealership, he says removing some factory shims will bring the rear end down some. I'm not looking to slam the truck, the nose will be kept at stock height. I intend to later pick up a set of chrome 22's for the summer, and keep the stock "chrome-clad" 5 spokes for winter. Just wondering if anyone knows whether or not the removal of these shims will lower the rear significantly, or if I should look at actual kits and so on.
also, as random as it is, I nearly died laughing from this --->
though that may also be partly a side-effect of the painkillers lol
2008 F-150 XL 4x4
5.4L V8, Tow Package
Forest Green/Pueblo Gold
Blue08 is offline
post #2 of 5 (permalink) Old 04-10-2009, 07:17 PM
If its a 4x4 you can just remove the factory 2" block from the rear [I would check the drive-shaft angles if I did this], or install a leveling kit up front
post #3 of 5 (permalink) Old 04-10-2009, 08:10 PM Thread Starter
Blue08's Avatar
Thanks, I had assumed what the guy meant by "shim" was the blocks. What I didn't know was how large they were, and I wasn't swift enough to ask how thick they were when I was there. Since I'm walking with a cane and can hardly bend over, getting under to measure would have been near impossible. He (the service manager) said they'd (the dealership) do it and check everything afterwards.
2008 F-150 XL 4x4
Blue08 is offline
post #4 of 5 (permalink) Old 04-10-2009, 09:00 PM
What he would have meant by shim is, when removing the block in the rear the drive-shaft would sit at a different angle to correct this it would have to be measured and possibly have to be shimmed, to the correct angle, a good angle would be negative 1 to 2 degrees so when you put your foot into the gas pedal and the rear end moves up a degree or two it should be perfect , I was told to steer away from aluminum and Brass shims and to use steel
post #5 of 5 (permalink) Old 04-11-2009, 05:44 AM
swackly's Avatar
The factory block is 1.75 inches high
swackly is offline
Rear Suspension Lowering Kit fordtough.ca Suspension 40 07-08-2010 12:18 AM
Rear end leaking Bruicer Driveline and Transmission 3 04-01-2009 11:09 PM
NEED HELP: Rear Lowering Kits Bates88 F-150 2004 to 2008 Forum 10 03-02-2009 11:49 AM
Rear end tag swackly F-150 2004 to 2008 Forum 3 01-06-2009 06:59 AM
Rear end problem alpine F-150 2004 to 2008 Forum 13 04-29-2008 09:50 PM
