Rear-end height on 2010 SCREW (Shackle??) - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 11-03-2009, 02:55 PM Thread Starter
Howdy,
Just ordered my new 2010 FX4 SCREW 6.5' truck. My problem is the overall height of the truck is 77" i believe which is about 1" too high to fit in the parkade at work. I spoke with my dealership about this and found out the crew cab is 4" higher than super cab. They let me borrow a truck to physically verify if there is space and I confirmed it's about 1" too tall.
I was thinking maybe a shorter shackle would drop the rear enough to allow it to fit. I know it's all about angles....how much does 2" drop at the rear translate to height in the cab area? Do to the sloping up it's only the last 6" or so of the cab that's too high. It's so close!
Any ideas or options? I REALLY don't like the dropped look so I would want to stay minimal...I'd rather go the other way
Sailor is offline
post #2 of 12 (permalink) Old 11-03-2009, 03:34 PM
you can get a drop shackle and add air bags to rear for hauling.
post #3 of 12 (permalink) Old 11-03-2009, 06:34 PM
get an fx2 lol
post #4 of 12 (permalink) Old 11-03-2009, 07:41 PM Thread Starter
Originally Posted by BIGPHIL View Post
get an fx2 lol
I don't think so...
It still has to work as a truck. Air bags are an option but fairly pricey. Had them on my Durango with manual filling. Wouldn't do that again...got to have the onboard compressor and gauges to work properly. That adds lots of money and complication.
Sailor is offline
post #5 of 12 (permalink) Old 11-04-2009, 12:45 AM
tohi2care's Avatar
Originally Posted by Sailor View Post
I don't think so...
What are your other options? Sounds like the best one to me.
tohi2care is offline
post #6 of 12 (permalink) Old 11-04-2009, 08:27 AM
Smaller Tires?
post #7 of 12 (permalink) Old 11-04-2009, 09:44 PM
How about move lol Guess you don't think before you ordered just my thought
post #8 of 12 (permalink) Old 11-05-2009, 12:37 AM Thread Starter
Ok a$$monkey yeah I thought about it...I'm trying to find a better solution that moving. If you took the time to read my post (assuming you can read) you'll see that I did actually test the truck before ordering. I was fully aware of the situation prior to ordering and looking for suggestions to help.
God I knew it was a bad idea posting anything on this forum. It's too much to actually expect someone to provide a legitimate comment. If you take the time to write a smart-a$$ response why not take the same time to put some thought into it.
Figures...
Now back to the original question...rather than parking 10 blocks away I'd rather find a way to lower the cab height by 3/4". Any thoughts as to whether or not a shackle drop might do it?
Sailor is offline
post #9 of 12 (permalink) Old 11-05-2009, 03:49 PM
Figures...
ok play nice children!,a 2"drop shackle will equalise the front/rear height,only problem will be load capacity.
post #10 of 12 (permalink) Old 11-05-2009, 03:55 PM Thread Starter
I ordered the truck with Max Tow, so I assume by changing shackles I will negate the entire benefits of the max tow? How much do you think it will affect payload? I hadn't thought of that.
Sailor is offline
Rear End Leaking :( funford F-150 2004 to 2008 Forum 8 09-01-2009 04:07 PM
Rear end cover? joetalon F-150 1997 to 2003 /04 Heritage Forum 4 08-21-2009 11:24 PM
Rear end fluid ?? joetalon F-150 1997 to 2003 /04 Heritage Forum 4 08-20-2009 06:48 PM
Rear end tag swackly F-150 2004 to 2008 Forum 3 01-06-2009 07:59 AM
Rear end problem alpine F-150 2004 to 2008 Forum 13 04-29-2008 10:50 PM
