Can it work? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 05-19-2010, 05:07 PM Thread Starter
Can it work?
Hello, my name is Nathan and I am new to the forums. I own a f-150 STX super cab and couldn't be happier with it. One thing I was thinking about was raising it. My biggest concern is that it is only a rear wheel drive truck, and it might kinda get laughed at or might really bog it down, aswell as put my fuel economy into the ground. I was not thinking like a 7 inch kit, I was thinking more so like a 3 inch and throwing bigger tires on it, or should I just put the bigger tires on it. Whats your oponion? And what would I be looking at in terms of pricing?
07STX is offline
post #2 of 10 (permalink) Old 05-19-2010, 05:54 PM
you wouldn't be the first that has done it to a 2wd truck
post #3 of 10 (permalink) Old 05-19-2010, 06:36 PM
Yes MPG will go down!
post #4 of 10 (permalink) Old 05-19-2010, 06:51 PM
wolfman1's Avatar
If you like it,who cares what anyone else thinks.
Like Taisa said You're not the first.
wolfman1 is offline
post #5 of 10 (permalink) Old 05-19-2010, 08:50 PM
I would go with a small lift and bigger tires but thats me.
post #6 of 10 (permalink) Old 05-20-2010, 01:43 AM Thread Starter
How much would I be looking at for a 3" kit? I have found a wide range of prices.
07STX is offline
post #7 of 10 (permalink) Old 05-21-2010, 02:43 PM
why not go with leveling spacers in front to fit bigger tires.
post #8 of 10 (permalink) Old 05-21-2010, 10:03 PM
what i did with my fx4 was put a rough country leveling kit in the front($100) and a set of firestone ride rite air bags in the back..it gave me a nice lfit and make it look alot better.
greger is offline
post #9 of 10 (permalink) Old 05-21-2010, 11:03 PM
the Firestone system is only to load level. It don't believe it actually lifts the truck.
I would suggest a front leveling kit.
then some 33"s and bushwacker fender flares.
will look pretty good!
aka I had one like that. but 4x4
here's a sample.
I debated adding a rear block or add-a-leaf to the back to raise it a tad more. but left it.
post #10 of 10 (permalink) Old 05-22-2010, 08:29 PM
actually the ride rite does lift the truck a good 3-4" depending on how much presure you add and it gives you a better ride then putting in the add a leaf becuase and add a leaf will be stiffer all the time while the air bags you adjust to what you want/need
greger is offline
work truck techdogg Truck/SUV Talk 0 12-10-2008 10:12 AM
i had this cut out at work Lilbigtrk Ranger Forum 9 08-17-2008 01:45 AM
Body Work sryan Atlantic Provinces (NF, NS, PEI, NB) 3 07-10-2008 08:29 PM
My Work Truck Bush_aholic Photo and Video Gallery - Members Rides 2 03-12-2008 12:15 AM
