NEED HELP: Spring Shackle Relacement - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 10-18-2010, 08:13 PM Thread Starter
any of you guys had to replace the spring shackles in your truck. My drivers side rear shackle broke and now the spring is resting against the bottom of my box. Need to know how much of a PITA it's gonna be
post #2 of 4 (permalink) Old 10-18-2010, 09:03 PM
Been there, done that. Common problem on F-series trucks. The worst part is getting new bolts in place of the factory rivot's. I did that job on my '95 F-350 and wished I had taken the box off as it would have been 100 times easier to get the new bolts in. Instead, I ****ed around with wrapping a piece of wire around each bolt to "fish" it thru the frame holes. If your rear fuel tank is fubar'd then this would be a great time to pull it out and do both jobs at the same time. However you do it, replace both shackle and spring hangers on both sides so you won't have to do it again. Another tip, have a 4' Jackall handy to lift the rear of truck up and away to line up springs and new hangers. Have a buddy around to help keep the truck steady while you're doing this part. As for the parts, I had to settle for Ford stuff ($$) cuz nothing else available for me on short notice. I'd buy new though...maybe LMC Truck parts. Good luck. and get a face shield too if you are dealing with a lot of rust falling when taking out rivots.
post #3 of 4 (permalink) Old 10-18-2010, 09:21 PM
yup did that job on my 88 f150 did both sides so I wouldn't have to do it again, a set of torches and a big hammer, punch, a forklift is nice but not everyone has use of one of those (lol) took me longer to remove the old shackels than to put it back together, by myself took me 2 hrs doing both sides.
post #4 of 4 (permalink) Old 10-18-2010, 10:25 PM Thread Starter
may have gotten lucky cause it's only the bottom part of the shackle that broke on me and it just has 1 long bolt holding it in there.
front shackle reversal kit hawker250 Suspension 0 09-24-2010 02:09 AM
Lift Shackle herbz Suspension 3 02-24-2010 11:16 AM
Rear-end height on 2010 SCREW (Shackle??) Sailor Suspension 11 11-05-2009 10:27 PM
Drop Shackle questions? f150phule Suspension 2 06-17-2009 01:20 AM
Spring Marc Carignan SVT Lightning 18 03-09-2009 05:29 PM
