882+tx for ball joints and tie rods + labor from the stealership - Page 2 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #11 of 12 (permalink) Old 08-22-2011, 11:03 AM
cdnarmyguy's Avatar
I get all my parts from NAPA or Bob's here in ST. Dealership is only for the none aftermarket stuff. In Petawawa and Fredricton, use to get a good discount at the dealership. I always buy the lifetime parts. My wife's Ex has gone through 4 upper ball joints. At 0$ its good just have to pay 120$ once.
It's a LEOPARD TANK
cdnarmyguy is offline
post #12 of 12 (permalink) Old 11-20-2011, 10:17 PM
I would agree that the price on those parts is expensive and aftermarket can be cheaper. But at the same time I am not sure of buying from Rockauto. What happens if they send you the wrong part or it has a manufacturing defect? Waiting even longer for parts. As a mechanic at a tire shop I check my prices fairly often. Sometimes the dealership has the cheaper price. I checked a Dodge axle u joint the other day and there was almost $100 difference between Dodge and Napa. As for the guy that paid $200 for a wheel alignment - they must have done a few adjustments. What most people don`t know is that most alignments only include adjuting toe. If you even go onto alldata and look up alignment labour times it show toe only then extra for caster/ camber adjustments and most shops wont tell u that until the job is done. i personally don't care if a person goes dealership or other store for parts but i do like to support local businesses as much as possible. You never know when you may need a favor from someone there. Just my 2 cents
roadapples is offline
Ball Joints swackly Suspension 8 10-16-2010 11:09 PM
ball joint replacement dwh Super Duty Forum 4 04-23-2009 02:06 PM
NEED HELP: U-JOINTS! Tetford4X4 Truck/SUV Talk 20 09-30-2008 06:50 AM
NEED HELP: 2004 U-joints johnnyo888 Driveline and Transmission 0 09-12-2008 10:46 AM
