2006 F-150 soft brake pedal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 12-01-2010, 12:11 PM Thread Starter
Got a 2006 F-150 with a soft brake pedal. If I pinch of the rear flex hoses, the pedal feels the same. If I pinch off the front flex hoses, the pedal gets rock hard like it should. This theoretically indicates that the problem is between the flex hose and the caliper. The truck has both BRAND NEW calipers in the front, new pads, and machined rotors. The system has been bled to the point where fresh clean fluid is coming out of the bleeder.
Anybody had this problem? Any advice?
loudmike is offline
post #2 of 4 (permalink) Old 12-01-2010, 05:14 PM
did you narrow down to what side?even reman calipers can have bad seals out of the box.
post #3 of 4 (permalink) Old 12-03-2010, 04:33 PM
90% of the time the soft pedal issue is caused by the actuator rod that is not adjusted right. Even a 16th of an inch off can lead to poor braking. You can do the fix yourself. The actuator rod is right after the MC. I'll come up with more info later... I have to go! But it's a cheap fix!
pat_28 is offline
post #4 of 4 (permalink) Old 12-05-2010, 02:07 PM
Hm might be too late but check this out.
pat_28 is offline
FOR SALE! 2006 Ford F-150 Super Crew greg86 F-150 2004 to 2008 Forum 1 06-13-2010 07:50 PM
cleaning products for soft tonneau. jdcrush Care & Detailing 4 07-05-2008 03:48 PM
Ford F-150 owners manual (1997 to 2006) fordtough.ca F-150 1997 to 2003 /04 Heritage Forum 0 11-30-2007 11:16 PM
Ford F-150 owners manual (1997 to 2006) fordtough.ca F-150 2004 to 2008 Forum 0 11-30-2007 11:16 PM
