NEED HELP: Soft brakes - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 02-16-2011, 08:52 PM Thread Starter
Soft brakes
Hello everyone, i own a 2001 ford ranger and been having some issues with it lately. In May i replaced my front pads and rotors.. about a month ago i noticed my brakes are getting soft, the pedal goes down quite far and then the brakes engage. I checked my pads and rotors, bled the lines.. checked my vacuum lines. Did not loose any fluid, MC and brake booster both look fine..
I only have a couple of ideas.. maybe there is air in the ABS system?
and i have recently heard of someone with the same problem and they adjusted the actuator rod (located between the booster and MC)... but why would it need adjusting out of the blue?
any thoughts ideas?
thanks in advance.
01FordRanger is offline
post #2 of 3 (permalink) Old 02-17-2011, 02:42 PM
if you have drum brakes in rear they need adjustment.
post #3 of 3 (permalink) Old 02-22-2011, 10:37 PM Thread Starter
Thanks! i was going to check them eventually anyways.. they were changed recently so i figured they would be fine. but it turns out my rear drums were completely shot... had to change drums/shoes/springs and MC's.. i have working brakes now.. have to work on my parking brake which is always engaged a little bit.
thanks again, problem solved.
2006 F-150 soft brake pedal loudmike Suspension 3 12-05-2010 02:07 PM
Who needs brakes? tohi2care F-150 2004 to 2008 Forum 0 07-15-2009 12:23 AM
brakes fullyford F-150 1997 to 2003 /04 Heritage Forum 8 04-11-2009 04:18 PM
cleaning products for soft tonneau. jdcrush Care & Detailing 4 07-05-2008 03:48 PM
help - squeaky brakes lightning25 Wheels and Tires 6 06-20-2008 04:10 PM
