Command Start Programming - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 11-19-2011, 03:31 PM Thread Starter
Exclamation Command Start Programming
Does anyone out there have a programming guide for a CS310i Command Start?
I have a generic one but it does not allow for the timed interval for the glow plug relay. TIA
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod, NC Hornet's CCV Mod
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
BD Power Auxiliary Trans Filter Kit
Diesel Site Coolant Filtration System
PSD911 is offline
post #2 of 7 (permalink) Old 11-20-2011, 08:45 AM
I'm not sure about that brand but I know I had to add a timer to my Viper. Are you sure it is part of the RS and not an add-on?
post #3 of 7 (permalink) Old 11-20-2011, 08:48 AM
i know for diesel u need a special one made for diesel
gilligan is offline
post #4 of 7 (permalink) Old 11-20-2011, 03:54 PM Thread Starter
It worked fine in the past. It just lost its brains when I changed out the batteries in the truck.
4"SS MBRP Exhaust
PSD911 is offline
post #5 of 7 (permalink) Old 11-20-2011, 09:36 PM
Not the actual manual, but maybe this will be enough to get you going?
http://www.the12volt.com/installbay/...asp?TID=101442
post #6 of 7 (permalink) Old 11-20-2011, 09:44 PM
One thing you can do which might help prevent this in the future, is to make up a little "battery backup".
Wire a 9 volt battery clip, a diode to isolate the 9 volt battery, to a 12 volt cigarette lighter plug. When you disconnect the vehicle battery, the diode will switch on and the 9 volt battery and backfeed through the vehicle's fuse box. It will provide enough voltage to keep the memory in your remote start alive while you change the starter battery.
I'm pretty sure you can buy something like this already made if you don't feel like doing it yourself. Probably would only cost a few dollars.
post #7 of 7 (permalink) Old 11-23-2011, 12:46 AM Thread Starter
Thanks for the help gang. I'll keep you posted on the progress. That's a good idea b4000 I think I'll do that or change one battery at a time. I did find a CSI2700 program guide . thanks for the link.
4"SS MBRP Exhaust
PSD911 is offline
Superduty tow command cobraclone Audio and Electronics 4 07-24-2010 04:05 PM
Factory Nav re-programming??? HD Chrome Audio and Electronics 2 10-29-2009 08:09 PM
How to use Keyless Entry Pad & Programming remote transmitters Oreo Sticky Tech/How to Section 5 08-17-2008 11:03 AM
:signs154: Fast and the Furious 4 Programming Groovy Chick Programmers and Tunes 6 05-20-2008 11:13 PM
Roush Programming. The_harleyryder Programmers and Tunes 3 01-17-2008 12:09 PM
