NEED HELP: Oil filter recommendation on a 99 7.3 turbo. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 05-08-2012, 08:44 PM Thread Starter
I just bought this truck and it seems like a gem so far, so I want to take good care of it. I noticed that the last filter was a Fram and I am coming due for a change, and was wondering what is recommended for a good engine oil filter.
Oakbank Ron is offline
post #2 of 12 (permalink) Old 05-08-2012, 09:03 PM
Motorcraft or purolator. Stay away from that orange can of death
post #3 of 12 (permalink) Old 05-08-2012, 09:13 PM
You can't go wrong with the Motorcraft (Ford) FL1995 or the Donaldson P550371.
LOOSEWHEEL is offline
post #4 of 12 (permalink) Old 05-09-2012, 07:32 AM
I agree with the two above.... there are vids on youtube that explain some of the different filters and show whats in them when cut open... most dont do much.
post #5 of 12 (permalink) Old 05-10-2012, 09:39 PM
zip
zip's Avatar
Find out who makes the filters for the 7.3 and go with that.
For my 6.0 I use Fram which are made by Racor which supply Ford with oil and fuel filters.
Chris
75 F150, 79 Bronco
zip is offline
post #6 of 12 (permalink) Old 05-11-2012, 02:50 AM
I use Wix filters on my clubwagon, mainly for the availability instock at work.
when I buy them other than from work, I use the FL1995 motorcraft or a fleetguard equivalent, can't remember the # anymore.
Fram and Baldwin spin on filters I have seen leak at crimped seam next to the seal surface, so I won't use either one.
you have a good longlife engine if you service it right. my clubwagon has almost 400,000 on it, last tank of fuel worked out to 22.1 mpg a lot of short trips and not much highway. I don't baby it either, but it gets looked after service wise.
good luck with your new to you truck.
68Mercury250Ranger is offline
post #7 of 12 (permalink) Old 05-11-2012, 03:00 AM
zip
zip's Avatar
I wont use a fram spin on my gassers but with the diesel it's one of the recommended filters.
Chris
75 F150, 79 Bronco
zip is offline
post #8 of 12 (permalink) Old 05-12-2012, 01:54 PM
I have a cousin that used to work for purolator he told me they made the motorcraft. Oil filters.
post #9 of 12 (permalink) Old 06-07-2012, 07:12 AM
Big Daddy D.'s Avatar
I would recommend that you go with the K&N # HP-6001 oil filter for your 7.3L.
They also list a cold air filter kit # 57-2530 as well (min. 14 Hp gain)
Press on regardless!
Big Daddy D. is offline
post #10 of 12 (permalink) Old 06-07-2012, 01:32 PM
unless your going big HP stay away from cold air kits for diesels.... sure they let more air in but no aftermarket filter can match the factory one for filtration. Its those small particals that kill turbo's fast plus add to other problems.
Oil filter removal ninjabill F-150 2004 to 2008 Forum 15 12-20-2008 12:57 PM
Oil Filter Housing PMarch Ranger Forum 6 09-05-2008 01:47 PM
Bypass Oil Filter 98 Ranger Rebel Gas Engines 3 02-10-2007 02:17 AM
