NEED HELP: Wiring nightmare !!!! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 07-08-2013, 07:22 PM Thread Starter
Ok this is the low down. Lets just start with wirring is not my fortay and iam sure I messed some wirring up along the way pervious too the problem iam gunna post
I changed the left bank Uvs gasket and external plug had a issue with the 110 volt wires matching the aftermarket Iam going too re wire this. But she ran fine then all of a sudden iam drivin along and wait to strt light comes on as truck loses power. But runs really rough let off the throttle she stops good too go also feels likes the clutch pops out but it's not it jut jerks and hops hard like it does
It also will "power surge " in idle the truck almost dies out then runs normal and if I let it idle Long enough it does that but soon as I engage the clutch and start too drive it dies .... This makes no sense what sensor is doing this. Solonoid I have no clue where too start ...
Pitbull is offline
post #2 of 5 (permalink) Old 07-08-2013, 10:16 PM
Start by reading the dtc's from it.
post #3 of 5 (permalink) Old 07-09-2013, 03:30 AM Thread Starter
As in dtc u mean the engine codes it's throwing. Well that's the best I forgot too mention no check engine light and no codes thus far
Pitbull is offline
post #4 of 5 (permalink) Old 07-09-2013, 07:04 AM
Air filter or fuel filter? Fuel pressure? Not everything is noticed by the ECM.
post #5 of 5 (permalink) Old 07-09-2013, 12:03 PM Thread Starter
Brand new fuel filter 3 rd last month and I got k&n filter iam going too test fuel pressure today but I think it's definitely something electrical
Pitbull is offline
Wiring Harness Trucksalltheway F-150 2009 to 2014 Forum 0 05-14-2012 11:36 AM
6 cd changer radio nightmare cadian Audio and Electronics 4 01-13-2012 06:29 AM
LF Wiring Diagram Swoosh66 F-150 2004 to 2008 Forum 5 11-18-2008 09:08 AM
Anybody on wiring ? Umaxman Audio and Electronics 2 05-25-2008 08:44 PM
