6.0 vibration head ache!
NEED HELP:
2K views 7 replies 4 participants last post by  Fordsforever6.0
#1 ·
I've got a 2004 F250 4x4 with the 6.0 diesel 300 000 km. Lately it has developed a nasty vibration. Here's what I've got so far:
Cold starting not a problem, no error codes, idle is steady, vibration is most noticeable @ about 1500 rpm and is at its worse when cruising at 80 kph, vibration is less noticeable when in tow/haul mode, doesn't matter whether engine is hot or cold.
I replaced a bad FICM and the situation slightly improved.
Any suggestions?
#3 ·
Keep replacing.
#4 ·
What are you using for a code reader? Some generic ones won't pick up codes that you want to see. My gut says you might have an injector issue...this is where a good code reader will help. A dealership or a shop that works on diesels might need to assist you.
#8 ·
If they happened to tell you, you need a new ficm, go with Ed at http://ficmrepair.com/. He is the best guy for these things. Also make sure your batteries and alternator/charging system are good. Your ficm is finicky with incoming voltage.
