f 350 water pump - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 04-27-2009, 10:58 PM Thread Starter
Cool f 350 water pump
2003 6L turbo diesel f 350 with 480,000 kms, scored a service manual and going to do the water pump tomorrow, ( first prob with this truck in almost a year of trouble free running.)
patchwrx is offline
post #2 of 10 (permalink) Old 04-27-2009, 11:22 PM
tohi2care's Avatar
tohi2care is offline
post #3 of 10 (permalink) Old 04-28-2009, 08:52 PM
magnumpeei's Avatar
480,000km??? holy crap that's awesome!
magnumpeei is offline
post #4 of 10 (permalink) Old 04-29-2009, 07:30 PM Thread Starter
got it all apart and not the pump. there must be a crush sleeve between the manifold and front plate behind the idler, leaking from there. bad to worse. sounds like bars leak to me. back at it tomorrow.
patchwrx is offline
post #5 of 10 (permalink) Old 04-29-2009, 11:45 PM Thread Starter
waffles anybody?
patchwrx is offline
post #6 of 10 (permalink) Old 04-30-2009, 09:06 AM
Ouch!
post #7 of 10 (permalink) Old 05-12-2009, 12:37 PM Thread Starter
suggested posibilities, injector O rings, oil cooler, or head gasket. has to come apart as far as intake anyway and head gasket seems to make the most sense to me. Tips would be welcome.
patchwrx is offline
post #8 of 10 (permalink) Old 05-12-2009, 03:00 PM
if you have a coolant leak at the front the most common thing i've seen is the coolant supply tube to the egr cooler and the intake return o-ring.
post #9 of 10 (permalink) Old 05-12-2009, 10:11 PM Thread Starter
oil in coolant
I have that, plus oil in the coolant, thought that might have caused the O ring failure.
patchwrx is offline
post #10 of 10 (permalink) Old 05-13-2009, 02:54 PM
if you have oil in the coolant it's the oil cooler,it's a pita to clean the cooling system after(takes 5-6 coolant flushes to get it clean)
06 lariat fx4 f 350 gewiens Super Duty Forum 10 04-09-2009 12:39 AM
Wheelin the 350 Fordwheeler Off Road 11 03-31-2009 05:01 PM
NEED HELP: removing door panels '06 F-350 firefighter38 Super Duty Forum 3 03-22-2009 08:19 AM
Lifting a F-350 osr1 F-150 Pre-1997 Forum 6 04-29-2008 06:53 AM
fuel pump noname42 F-150 Pre-1997 Forum 5 03-26-2008 08:07 PM
