NEED HELP: Engine Stall - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 21 (permalink) Old 01-02-2010, 03:39 PM Thread Starter
Engine Stall
Just wondering if anyone can help me with my truck. As I was driving along, the engine started knocking, losing power and finally just stalled. I have a 2000 Excursion 7.3L, and as I'm not the original owner I automatically went to the fuel filter, because it sounded like it was starving for fuel. I changed the fuel filter and the truck still doesn't want to start. It cranks and tries to fire, but won't. Any suggestions?
oilman is offline
post #2 of 21 (permalink) Old 01-02-2010, 03:58 PM
not to shure the one to ask would be shelbyx1....... ( I.P.R pump) maby
post #3 of 21 (permalink) Old 01-02-2010, 04:54 PM Thread Starter
engine stall
I think the original problem was a dirty fuel filter. I've changed the filter and the truck won't start. It keeps cranking but won't start. Could it be a vapor lock? If so, how can I get the air out of the system?
oilman is offline
post #4 of 21 (permalink) Old 01-02-2010, 06:41 PM
If 7.3's are run dry they can be a bast... to get restarted. It's been while but if I recall there is a way of letting air out at the fuel filter on the engine. I can't remember if there is a plug, valve or it the cap has to be loosene dwhile you crank it over until you get all fuel and no air. Can postion sensors were am issue on the 7.3's as well but I don't know exactly what conditions to look for.
post #5 of 21 (permalink) Old 01-03-2010, 02:23 AM
When you crank the truck, does the tach register RPM??? If not, replace the CPS. Better yet, take it to FORD and have it replaced under the recall notice. Do you have access to an OBD scanner???
LOOSEWHEEL is offline
post #6 of 21 (permalink) Old 01-03-2010, 02:26 AM
zip
zip's Avatar
My first thought was the CPS.
Chris
75 F150, 79 Bronco
zip is offline
post #7 of 21 (permalink) Old 01-03-2010, 09:20 AM Thread Starter
CPS was changed at my Ford Dealer under recall about a year or so ago.
oilman is offline
post #8 of 21 (permalink) Old 01-03-2010, 09:24 AM Thread Starter
Is there more than one fuel ilter on these trucks?
oilman is offline
post #9 of 21 (permalink) Old 01-03-2010, 11:49 AM
Just because it was changed does not mean it will not fail. Double check to see if you register RPM when you crank.
When you 1st turn the key on, can you hear the fuel pump turn on?
Have you checked your oil level?
Only one fuel filter in the bowl on top.
post #10 of 21 (permalink) Old 01-03-2010, 12:26 PM Thread Starter
With the key in the on position, i listened underneath where the fuel pump is and could hear a buzzing noise, I assume that means the pump is working? Is that how the pump is supposed to sound or is it louder?
oilman is offline
4.6 -4.6 engine swap littlebronc Gas Engines 10 06-18-2009 11:09 AM
NEED HELP: 4.6 Engine Trouble Bruicer Gas Engines 2 02-07-2009 12:51 AM
NEED HELP: 5.4 Engine Missing SCrewFarmer Gas Engines 14 01-20-2009 08:44 PM
Ranger Engine? fordtough.ca Ranger Forum 13 03-16-2008 07:40 PM
engine code?? silverfox Gas Engines 7 09-12-2007 10:05 PM
