ABS light - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 09-28-2010, 10:02 PM Thread Starter
ABS light
I have a new to me F250 2005 6l 4x4. When I hit the brakes and turn to the right, the brake pedal vibrates and the abs comes on. It goes out after a bit. A mechanic told me this means either a wheel bearing is going or an abs sensor. Does this sound true. Are these wheel bearings tough to change? Also, this 6l has 195k on it and has never had a problem, so says the original owner. Do some of these last this long? I am scared to drive it without doing the cooler,egr and head studs Thanks.
swampthing is offline
post #2 of 3 (permalink) Old 09-29-2010, 10:03 AM
Horchata's Avatar
The 6.0 replaced the 7.3 in 2003 I believe. The first runs were consider flaky for a variety of reasons from the new variable vane turbo to the PCM to the new ridiculous emissions junk. The later models are supposedly better, your 2005 is probably pretty safe for those particular issues, and just is going to have the more usual run of the mill type issues. I wouldn't worry about a stock engine needing head studs. I don't know enough about the PCM to say what version is safe, but you could always check for recalls and see if yours needs to be flashed http://www.ford.com/owner-services/c...ll-information
As for brake pedal vibration...I myself wouldn't have though of wheel bearing from that, but if there is ever any suspicioun of a wheel bearing you should jack it up and brace it and inspect. Any play and it has to be replaced. If it is a sensor, you could try troubleshooting it by tracking down the sensor, disconnecting it, and seeing if you can recreate your problem.
1997 F250 HD XLT, 4x4, E40D, 4.10 limited slip 265/75 KM2s 300k mi
2002 Escape XLT, auto, tow package, Cooper disco STTs, 120k mi
Horchata is offline
post #3 of 3 (permalink) Old 09-29-2010, 08:52 PM
atk
atk's Avatar
Send a message via MSN to atk
as stated in your other thread, get your truck scanned for codes. this should help pinpoint which front sensor/wheel bearing is your problem area....
as for reliabilty of the 6.0L`s. they need to maintained properly. yes they did have a few problems early on, but most was taken care of 2005. also, don`t baby these motors, which includes extended idle times....if you plan on working the truck hard, plan on doing head studs, egr delete, and a exhaust system to start with....a tuner is also a good idea, along with some guages.
if your truck is out of warranty, stay away from Ford reflashes, they will usually kill mpg`s and power. talk to people at Power Hungry Performance about FICM reprogramming and possible Ecm rollback....
2004 FORD F-250 XLT 4x4 C/C S/B....
Sct-Livewire with custom tunes, guages, 4" exhaust,coolant filter....soon to be tuned by PHP....
atk is offline
abs light albertaboy Sticky Tech/How to Section 3 04-09-2016 01:22 PM
ABS light swampthing Diesel Trucks 1 09-27-2010 07:42 PM
Better light for pics v8ranger Ranger Forum 1 12-31-2008 01:20 AM
ABS heavyhitter F-150 2004 to 2008 Forum 6 12-16-2008 10:00 PM
