Check Engine light - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 03-19-2011, 05:32 PM Thread Starter
Check Engine light
The check engine light on my new to me 97 F-150 comes on once in a while. I put it on a scanner and I got code P0402 (exhaust gas flow excessive detected) What does this mean?
post #2 of 5 (permalink) Old 03-19-2011, 06:14 PM
A code P0402 most likely means one or more of the following has happened:
The DPFE (differential pressure) sensor is faulty and needs to be replaced
There is a blockage in the EGR (most likely carbon buildup)
The EGR valve is faulty
The EGR valve may not be opening due to a lack of vaccuum
Possible SolutionsWith a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
Check the voltage at the DPFE sensor both at idle and when the EGR is open
Replace the DPFE sensor
i found this here
http://www.obd-codes.com/p0402
post #3 of 5 (permalink) Old 03-19-2011, 09:22 PM Thread Starter
Thanks, I'm gonna bookmark that site.
post #4 of 5 (permalink) Old 03-19-2011, 09:53 PM
I hope it helps..those codes can mean so many things.
post #5 of 5 (permalink) Old 03-19-2011, 10:27 PM Thread Starter
I joined up cause my brother inlaws F-350 is giving him a few different codes too. We just got the scanner and are a little confused with all the different codes from the 3 different vehicles we are scanning. Better than throwing momey away guessing what parts need replacing.
Check Engine Light funford F-150 2004 to 2008 Forum 13 04-11-2009 08:29 AM
NEED HELP: Check engine light on oilman Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 5 10-09-2008 11:43 PM
Check Engine but no codes? truckguy94 F-150 Pre-1997 Forum 23 09-06-2008 04:36 PM
WTF- Check engine light? Viper238 Gas Engines 12 05-20-2008 01:52 PM
engine light on...help!! lightning25 Gas Engines 8 10-18-2007 10:21 PM
