2002 F150 PCM - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 04-20-2011, 03:31 PM Thread Starter
2002 F150 PCM
Has anyone evry had to change the PCM in their truck? If so what was it doing? Mine has inconsistant acceleration, almost like a dead spot. Tried coils, injectors, plugs, tested fuel pressure, cleaned MAF.
Haley-Special is offline
post #2 of 4 (permalink) Old 04-20-2011, 03:47 PM
prairiethunder's Avatar
We actually tried this on my old '99 f150. After hours of messing around we finally gave up, and took it to the local mechanic rather than the dealer. It took them 3 hours to get all the codes right.
I did a search for you and found a thread on another forum, thought it might be helpful to ya.
http://www.f150online.com/forums/v8-...-f150-pcm.html
Good luck.
prairiethunder
2007 F-150 FX4
2007 F-150 King Ranch
1989 F-150 XLT
1949 F-1
prairiethunder is offline
post #3 of 4 (permalink) Old 04-20-2011, 03:54 PM Thread Starter
was the truck doing the same thing as mine, did the new comp fix it?
post #4 of 4 (permalink) Old 04-20-2011, 03:57 PM
Pretty much, it was fine most of the time, but sometime would bog right down, other times the rpm's would spike for no reason. I cant remember exactly how much I paid for it, but I know the mechanic did it for about half of what the dealer did.
prairiethunder
2007 F-150 FX4
1989 F-150 XLT
1949 F-1
2002 F150 4.6L Haley-Special F-150 1997 to 2003 /04 Heritage Forum 8 03-17-2010 11:51 AM
2002 F150 4.6L Haley-Special F-150 1997 to 2003 /04 Heritage Forum 2 02-26-2010 04:03 PM
NEED HELP: 2002 f150 won't start unless steering colum is down HOTDOG Gas Engines 2 12-05-2009 07:10 PM
Read code 542, Fuel pump secondary circuit failure, PCM to ground. mika Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 10-06-2009 01:31 AM
2002 f150 shift on the fly Haley-Special F-150 1997 to 2003 /04 Heritage Forum 11 10-02-2009 03:42 PM
