1998 F150 Power Window Problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 06-23-2011, 05:15 PM Thread Starter
Hello all, get this. I have a 1998 f150 and the driver's side power window refuses to go down. It goes up alright, goes down if i install a jumper at terminals 30 and 87 at the one touch down relay with the relay removed, OR if i remove the 5 amp fuse at fuse position #15 and re-install it (and the window will go down all the way without hitting the 'down' button). Any ideas?
vandervm is offline
post #2 of 3 (permalink) Old 06-23-2011, 05:38 PM
wolfman1's Avatar
The switch
wolfman1 is offline
post #3 of 3 (permalink) Old 06-23-2011, 05:49 PM Thread Starter
switch is good.
vandervm is offline
NEED HELP: Change Power window motor 1995 F250 bckid Sticky Tech/How to Section 3 07-03-2010 11:14 PM
Driver's side power window Haley-Special F-150 1997 to 2003 /04 Heritage Forum 5 03-31-2010 12:56 AM
Power Window Problem TowRig Audio and Electronics 2 10-09-2009 08:47 PM
Power Window Mod Oreo Sticky Tech/How to Section 0 08-01-2008 11:39 AM
power window wiring nnik F-150 Pre-1997 Forum 9 03-01-2008 03:39 PM
