engine light came on - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 06-28-2011, 09:55 AM Thread Starter
Smile engine light came on
i have a 1997 f150 with a 4.2 engine light came on and we put computer on it and says lean in both banks sides my o2 semsors were changed this winter mecanic told me its probably a vaccum leak when i am in gear at a drive trought and in gear i have a lot of vibration on the steering and when i put in neutral it goes away
gilligan is offline
post #2 of 5 (permalink) Old 06-29-2011, 02:00 AM
Yep sounds like a vac leak. I recently had one, it was on that little rubber elbow just below the throttlebody, damn part cost me $24 since its a dealer item only. I'd take a close look at all of your vac. lines. Simple way to check is with the motor running spray some throttlebody cleaner on them, if the idle gets rough when you spray you've found the leak.
post #3 of 5 (permalink) Old 06-29-2011, 10:59 AM Thread Starter
we are going to put a smoke machine on it within a few days i hope to see where it is leaking hoping wont be to long to find it
gilligan is offline
post #4 of 5 (permalink) Old 06-29-2011, 02:10 PM Thread Starter
hi i went and checked at the same place as you and bingo the same problem but we just used a spark plug rubber cap it does the same job cost me nothing but my time
gilligan is offline
post #5 of 5 (permalink) Old 06-30-2011, 01:53 AM
Nice, next time mine craps out I'll remember this trick.
check engine light 3323 Ranger Forum 12 04-22-2011 03:50 PM
Check Engine light Fordwheeler F-150 1997 to 2003 /04 Heritage Forum 4 03-19-2011 10:27 PM
Check Engine Light funford F-150 2004 to 2008 Forum 13 04-11-2009 08:29 AM
NEED HELP: Check engine light on oilman Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 5 10-09-2008 11:43 PM
engine light on...help!! lightning25 Gas Engines 8 10-18-2007 10:21 PM
