A/C problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 07-24-2011, 06:41 PM Thread Starter
lilbruicer's Avatar
Send a message via MSN to lilbruicer
A/C problem
i was just wondering what could be wrong with my ac you can have the air on but its not cold so looked at the compressor and it not even working but its moving freely but its not kicking in i was just wondering if it could be a relay or anything like that your help would be great thank you Brian
lilbruicer is offline
post #2 of 4 (permalink) Old 07-26-2011, 07:10 AM
Did you check the fuses?
post #3 of 4 (permalink) Old 07-27-2011, 12:08 AM Thread Starter
lilbruicer's Avatar
ya i checked them all i didnt see any breaks in them thanks
destructicon
post #4 of 4 (permalink) Old 07-27-2011, 09:56 PM
The system may be empty or low. Although I hesitate to suggest this, try pulling the high pressure switch plug usually located on or near the dryer. Test for voltage. One wire should have +12VDC. If so, jumper the plug just to see if the compressor clutch engages. Don't leave it on for an extended amount of time. You should only need 1 or 2 seconds. If it engages, see your local air conditioning technician. Also, if you have a UV light, look around the AC components for UV dye that looks like it leaked out of somewhere. Usually a spray or drip pattern.
NEED HELP: Transmission problem quad_racer_12 Driveline and Transmission 5 05-17-2012 08:21 PM
problem fordfan22 F-150 1997 to 2003 /04 Heritage Forum 2 06-12-2010 05:59 AM
egr problem!! thunder2010 Gas Engines 0 05-04-2008 02:26 PM
Same problem or new one?? Ottawaguy F-150 Pre-1997 Forum 11 01-02-2008 01:51 AM
