changing transfer case - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 08-23-2011, 04:06 AM Thread Starter
i have to change my transfer case in my truck way to much winining in it its been getting worse all the time we checked all u joints all good when i put it in 4x4 its alot worse its got 235000 kl on it so i hope this will fix the problem if not back to drawing board lol
gilligan is offline
post #2 of 6 (permalink) Old 08-23-2011, 04:36 PM Thread Starter
i changed transfer case and on 2 wheel drive a ok but on 4x4 its very noisey i am looking to try to bu a kit to rebuild my old 4x4
gilligan is offline
post #3 of 6 (permalink) Old 08-29-2011, 08:45 PM Thread Starter
we are going to open my old transfercase and see what is really wrong with it we are sure it is just bearings if it is we are going to put a bearing kit in it
gilligan is offline
post #4 of 6 (permalink) Old 08-30-2011, 10:27 PM
Get ready for a new chain.
post #5 of 6 (permalink) Old 08-30-2011, 11:03 PM Thread Starter
the chain ok fine it is not skiping at all it was working fine its in 2 wheel drive that is was noisy does the chain work when im in 2 wheel drive
gilligan is offline
post #6 of 6 (permalink) Old 08-30-2011, 11:43 PM
I'd have to look that up. I believe some do because it circulates oil at the same time, just can't remember which ones.
Recent transfer Fiddy New Members Introductions 6 07-03-2011 12:33 AM
transfer case shift motor haywire F-150 2004 to 2008 Forum 3 12-23-2009 09:01 PM
NEED HELP: transfer case problem simon1631 F-150 2004 to 2008 Forum 2 02-19-2009 03:23 PM
I grew up with a stick transfer case... Mar Ranger Forum 6 01-24-2009 08:32 PM
NEED HELP: Transfer Case Locked Up taisa899 Driveline and Transmission 6 01-18-2009 11:01 AM
