Replacement tail light connectors - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 09-16-2011, 02:56 PM Thread Starter
cdnarmyguy's Avatar
Fellas
Just was going to replace my 7 way trailer plug, and found out that the fella/someone cut the wires at the plug for the trailer/rear tail lights. Then spliced a bypass to the wiring. Is there anywhere I can get a new OEM replacement plugs complete or the brass inserts? Ill just cut all the wires and rewire. And not have to screw arround with a new harnesses complete.
The wires he had cut is the Blue and the Red from the main harnass. I cannot find the wiring diagram to tell me which ones they are for.
Thanks Dave J
It's a LEOPARD TANK
cdnarmyguy is offline
post #2 of 3 (permalink) Old 09-17-2011, 12:45 AM
Have you tried St Thomas ford ( eastway ) they may just have the harness you need, pretty sure the blue wire is live for electric trailer brakes, red if I'm right is stop lights but not positive. Or go to MacGregors auto wrecker and go in the yard find a truck crawl under it cut what you need and put it in your shirt then tell them you didn't find what you where looking for
post #3 of 3 (permalink) Old 09-17-2011, 09:33 AM Thread Starter
cdnarmyguy's Avatar
But don't want the complete harness. I had to replace a harness connector on my wife's Explorer years ago. Picked up the replacement ford connectors at Auto Plus. IT came complete no screwing around, just cut instert the brass connectors and done. But no Auto Plus supplier in southern Ont. Its just the male and female connectors I need. Ford only sells the harness.
As for the wiring, thats what I thought. The other option is to take it apart and pick up the brass inserts from NAPA.
It's a LEOPARD TANK
2010 Tail Light Issue lumberjack F-150 2009 to 2014 Forum 38 05-01-2011 12:50 PM
Built a LED 3'rd tail light! effexfour Exterior 5 06-24-2009 06:28 PM
Need tail light idea's LayinHp Projects and Build-Ups 6 10-14-2008 02:53 AM
Tail light guards tohi2care Off Road 7 08-06-2008 03:03 AM
