common switch - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 10-06-2011, 09:28 PM Thread Starter
cdnarmyguy's Avatar
common switch
Fellas
I found out just be accident, that all 99-03 Switchs are all the same. If you are looking to add autolamps, all you have to do is to remove a lil plastic from the back of the front plate. Will post pics when I get them. So all you will require is the Cover on dash (Oval)--P/N# XL3Z-15046A34-DAA(specify your color) 1353)Light Sensor-- P/N#YL3Z-13A018-AA .
It's a LEOPARD TANK
cdnarmyguy is offline
post #2 of 3 (permalink) Old 10-07-2011, 01:43 AM
Oh sure! If you wanna do it the easy way!
post #3 of 3 (permalink) Old 11-30-2011, 11:31 AM
Auto lamps are GREAT!!! Never have to turn on /off again (some times at my age you tend to forget to do both!) Now how about about auto wipers?
Ogre is offline
Broken Window switch murray99 Sticky Tech/How to Section 5 05-19-2011 10:12 PM
Thinking about by passing switch Mar Ranger Forum 14 04-01-2011 10:36 PM
clutch starter switch 1tonne Truck/SUV Talk 0 12-01-2009 12:43 AM
Pictures Wanted - Defrost Switch Blue Oval Interior 1 02-19-2009 11:07 AM
Interior fan speed switch Fordwheeler Interior 4 10-21-2008 11:55 AM
