power windows swap - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 11-10-2011, 08:32 PM Thread Starter
grinder4.2's Avatar
power windows swap
do you think it is possable to swap power windows out of a 98 f150 xcab xlt to a 98 f150 reg cab XL? is the wire for the windows and lock ran by there own harness or does it tie in to the main ? or is it cheaper and easy to wire in aftermarket and use oem power door panels?
grinder4.2 is offline
post #2 of 11 (permalink) Old 11-10-2011, 11:14 PM
You should be able to do that swap no problem the power window harness should tie into the main harness to the truck
post #3 of 11 (permalink) Old 11-11-2011, 05:26 PM Thread Starter
grinder4.2's Avatar
i look at my truck and my parts truck and my lx truck has no wires in the doors but the speakers
post #4 of 11 (permalink) Old 11-15-2011, 09:23 PM
if u take off the panel at your feet at the bottom on left their is a plug their
gilligan is offline
post #5 of 11 (permalink) Old 11-15-2011, 10:47 PM
IF the truck didn't come with power windows there would be no wiring in the doors for them, you would have to add the wiring from a donor truck along with the switches and window motors etc, the door wiring should plug into the main harness somewhere close to where it goes into the body from the door
post #6 of 11 (permalink) Old 11-25-2011, 09:18 PM Thread Starter
grinder4.2's Avatar
does any one have a pic of where the door harness plugs in to the main harness or if it does or confirm it part of the main harnes and does not unplug
post #7 of 11 (permalink) Old 11-25-2011, 10:48 PM
gilligan is offline
post #8 of 11 (permalink) Old 11-26-2011, 01:08 AM Thread Starter
grinder4.2's Avatar
so does the pw/pl harness run from the driver side kick panel up arpund the dash to the passanger side in to the door?
post #9 of 11 (permalink) Old 11-26-2011, 01:16 AM
I would believe each harness would plug in to each side of the harness LS to LS RS to RS
post #10 of 11 (permalink) Old 11-26-2011, 01:30 AM Thread Starter
grinder4.2's Avatar
if you look at the black truck(XLT) there is a good amount of wires that come thou the gromit and head upwards now in the red truck(XL) there is only the speakers and that heads down
Windows Tinted hogdust Photo and Video Gallery - Members Rides 19 01-06-2011 05:21 PM
Did you tint Your Windows? fordtough.ca Truck/SUV Talk 27 01-04-2009 05:56 PM
NEED HELP: 2004 f150 windows wont go down, 04fx4 Interior 1 09-18-2008 08:49 PM
