fog lights - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 17 (permalink) Old 12-04-2011, 10:48 AM Thread Starter
fog lights
hello i just installed fog ligtghs in my bumber of my truck and the lights stay on all the time even with key out of ignition and head lights swtich off would i need to replace my head light swtich????
gilligan is offline
post #2 of 17 (permalink) Old 12-04-2011, 12:51 PM
Ol Skool's Avatar
Wire it to the oppisite side of the ignition. Turn your key on, Check for a hot wire, turn your key off , check again, The wire should not be hot. Then it will only work with the key on.
I hope that's a help Gilligan
Gerry
Ol Skool is offline
post #3 of 17 (permalink) Old 12-04-2011, 02:26 PM Thread Starter
with my key off it stays on to
gilligan is offline
post #4 of 17 (permalink) Old 12-04-2011, 02:27 PM Thread Starter
i hope i can fix it
gilligan is offline
post #5 of 17 (permalink) Old 12-04-2011, 06:15 PM
Sounds like you tapped into a source that's hot all the time.
I'd say you need to find something either keyed to the ignition (as Gerry has suggested) , or install a manual switch between the existing power source and the lights.
Good luck, be sure to update your progress.
post #6 of 17 (permalink) Old 12-04-2011, 06:28 PM
it has to be you wired it wrong.
post #7 of 17 (permalink) Old 12-04-2011, 06:32 PM Thread Starter
i am using original wires that are their for the fog lights
gilligan is offline
post #8 of 17 (permalink) Old 12-05-2011, 01:46 AM
If your truck didn't come with fog lights then you need to either modify your headlight switch or get one already configured for fog lights. I've seen some writeups on this and iirc the way some guys got it to work with the existing headlight switch was they had to take it apart and remove a plastic tab or something like that, its the tab that prevents the fogs from working properly with the existing switch. I'll check some other forums for the writeup.
post #9 of 17 (permalink) Old 12-05-2011, 02:21 AM
This should help you out.
http://www.f150online.com/forums/art...-f-150-xl.html
post #10 of 17 (permalink) Old 12-05-2011, 09:54 PM
Do like some guys do and run new wires to the fogs to a new switch you can turn on/off when needed. Just my 2 cents
97-03 driving/fog lights klewis F-150 1997 to 2003 /04 Heritage Forum 5 01-22-2012 10:40 PM
Driving/ Fog Lights stubbyranger Ranger Forum 3 05-05-2010 09:42 PM
NEED HELP: Factory fog lights 09 FX4 Ranger Carl534 Ranger Forum 2 09-30-2009 11:41 PM
NEED HELP: FOG lights VooDoo Ranger Forum 2 09-02-2009 11:36 AM
NEED HELP: fog lights Full of water RichmondRanger Ranger Forum 3 01-15-2009 04:16 PM
