Some questions...alternator& Battery replaced...sometimes will not start. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 02-03-2012, 08:51 AM Thread Starter
nf150's Avatar
Question Some questions...alternator& Battery replaced...sometimes will not start.
I have to admit, this is really frustrating me...
I have replaced the alternator and have put in a new battery, and replaced the battery a second time under warranty..
This am the truck wouldn't start...It did start after a boost...but I think it should start every time with a new battery and alternator...
I have tested the alternator and I get the charge- 14.5 to the battery.
Any Ideas as to what may be causing the problem...
nf150 is offline
post #2 of 12 (permalink) Old 02-03-2012, 09:44 AM Thread Starter
nf150's Avatar
anyone....anyone...
nf150 is offline
post #3 of 12 (permalink) Old 02-03-2012, 11:53 AM
Try cleaning all ground connections and the connections to starter, solenoid.
post #4 of 12 (permalink) Old 02-03-2012, 01:20 PM Thread Starter
nf150's Avatar
it was a corroded starter terminal...all fixed for now
nf150 is offline
post #5 of 12 (permalink) Old 02-03-2012, 01:37 PM
Glad to hear you found it. When you're chasing ghosts start with the easy stuff first. Not as hard on the wallet!
post #6 of 12 (permalink) Old 02-03-2012, 08:50 PM
anyone....anyone...
Your post was up for a grand total of one hour. A touch impatient ?
Glad you found the solution by noon though.
post #7 of 12 (permalink) Old 02-03-2012, 09:32 PM
Guess he didn't want to be late for work ? how many guys are on here reading post at 7:50am ? I'm at work at that time
post #8 of 12 (permalink) Old 02-11-2012, 02:28 PM
Axehandler's Avatar
Just an FYI an old Taurus i had once did the above and it turned out to be a loose and corroded connections on the ignition switch in the steering column. Lots of power to battery etc. just wouldn't start sometimes.
My 2 cents
2003 F350 Super Cab XLT 6.0L
4.5 lift
35" tires
Her name is "Betsie"
Axehandler is offline
post #9 of 12 (permalink) Old 02-13-2012, 01:50 AM
I'm not surprised, mine did the same thing, just a loud snap when I tried to start it one day. The whole bolt assembly where the battery cable connects to the starter corroded and just fell off.
post #10 of 12 (permalink) Old 04-19-2012, 10:51 AM Thread Starter
nf150's Avatar
turns out it was the solenoid( on the fire wall) and the corrosion... since the changes no issues...
nf150 is offline
Replaced Front Licence Plate Bracket f150phule Exterior 7 07-22-2008 07:39 PM
Replaced Horn jdcrush Ranger Forum 13 07-15-2008 01:13 AM
Fancy alternator blueghost Wheels and Tires 7 04-23-2008 10:21 PM
