1997 lift questions - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 08-07-2012, 08:54 PM Thread Starter
1997 lift questions
Hey everyone
Names Justin I just joined.
I have only
Ever owned fords but the it my first newer model f150
So I have the 1997 4x4 offroad extended cab step side
And it is taller then my buddys normal ford
Just wanted to know did it come with a lift on it
I wanted to order in the torsion keys which are good
For 2-3 inch but wanted to make sure it was going to do something
Thank you
97Offroad4x4 is offline
post #2 of 6 (permalink) Old 08-07-2012, 09:10 PM
Your truck sits taller than you buddy's because it has the off road package on it also, I would stay away from aftermarket torsion keys they put too much angle on the CV joints And tear them up along with the CV boots. I would just turn up the factory torsion bars but not past a 27 degree angle
post #3 of 6 (permalink) Old 08-08-2012, 06:29 PM
KIETH F150's Avatar
don't piss around with after market keys! on my old 2000 f150 I cranked the factory T-bar, put a 2" body lift and ran 35" tire.
2012 XLT F150 (Sterling Grey)
Window Visors, Fender Flares
KIETH F150 is offline
post #4 of 6 (permalink) Old 08-08-2012, 11:24 PM Thread Starter
Thank you for the info
I will just crank them a bit
post #5 of 6 (permalink) Old 08-19-2012, 10:20 PM Thread Starter
So I turned them a couple of turns and they stoped but there is still
Half inch of thread left does this mean the are at max or binding
Input is great I have always owned solid axle trucks
post #6 of 6 (permalink) Old 08-20-2012, 12:30 PM
What I did when I turned mine up was put a floor jack under the lower A arm and then mark the bolt so you can count how many times you turn it Make sure you do both sides even with the full weight of the truck on the ground. Check out the C V. Angles I would t go past 27 degrees max. Or you may wear out your C V joints out prematurely and start tearing the boots. Remember the more you crank them the more angle you get. The stiffer the ride becomes
And after you get them where you like get an alignment
1997 Ranger XLT chrmar Ranger Forum 11 03-14-2012 02:56 PM
Ready Lift torsion key lift Ford00XLT F-150 1997 to 2003 /04 Heritage Forum 6 01-16-2010 11:33 PM
1997 ford f150 xlt farmerboy3 F-150 1997 to 2003 /04 Heritage Forum 7 02-20-2009 02:52 AM
NEED HELP: 1997 ranger 4x4 front hub Nanaimowill Ranger Forum 2 12-25-2008 01:08 PM
