changed o2 sensor - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 10-05-2012, 07:59 PM Thread Starter
changed o2 sensor
i have a 97 ford f150 with a 4.2 and the mecanic told m,e that one back o2 sensor stoped working so i had them changed and the same problem came back i spent 200 bucks to change them both the front ones were changed to
one year ago so now dont know what to do they tell me it could be main computer but is it or another reason to spend more money at my expence
gilligan is offline
post #2 of 10 (permalink) Old 10-05-2012, 08:15 PM
That sucks when you spend cash to fix a problem and then turn around and have it come back.
What sort of problem are you having that they would suggest replacing the O2 sensors ?
When the O2 sensors were replaced, did it fix the problem initially, and how long after they were replaced did the problem come back ??
post #3 of 10 (permalink) Old 10-05-2012, 08:30 PM Thread Starter
the mecanic had the scanner on and watching the o2 sensors and one stoped working so i relaaced them both back one
now one back one stays at 5 when i race engine then it starts working thats what was happening before i changed them
milage on truck almost 253000 i only did about 40 kl and light came back so i went back to garage and we put scanner back on and i dont know what to do if i should just park this truck or not im tired of putting money in and getting no where its fustrating
gilligan is offline
post #4 of 10 (permalink) Old 10-11-2012, 06:08 PM Thread Starter
now today truck was in garage again for 2.5 hours and still no go to find problem
gilligan is offline
post #5 of 10 (permalink) Old 10-11-2012, 08:34 PM
Have they traced the wires back to see if there's a broken one that is only making occasional contact?
post #6 of 10 (permalink) Old 10-11-2012, 11:27 PM
What's the DTC code it gives? And, what is the truck doing or not doing?
post #7 of 10 (permalink) Old 10-12-2012, 03:44 AM Thread Starter
the wires are working fine not sure of the code the garage did not give to me
gilligan is offline
post #8 of 10 (permalink) Old 10-12-2012, 03:45 AM Thread Starter
as soon as we spray air intake cleaner in the throttle body as the truck running the sensor reading goes to normal
gilligan is offline
post #9 of 10 (permalink) Old 10-12-2012, 10:03 PM
Try a compression test. Check vacumm and exhaust for leaks. Check injector spray pattern. Check Fuel pressure. I get the feeling that your problem may be more mechanical than electronic.
post #10 of 10 (permalink) Old 10-13-2012, 07:28 AM Thread Starter
i have spent over 300 bucks so far i think i will just leave it the way it is until it dies i wish these mo0tors did not take so long to change i would change it
gilligan is offline
changed winter to summer tires gilligan F-150 1997 to 2003 /04 Heritage Forum 5 04-10-2011 10:49 AM
Changed Muffler hogdust Intake, Exhaust 24 01-05-2011 08:12 PM
NEED HELP: Changed real axle. Still wobbles J.P. (Mount hope) Ranger Forum 16 11-28-2008 03:49 PM
I changed my muffler :) Bush_aholic F-150 2004 to 2008 Forum 11 09-15-2008 02:27 AM
